Question about Pioneer VSX-D498 Receiver
What is a good univeral remote to use with the VSX-D498
One that gets all the functions or most of them and doesn't cost an arm and a leg
    Problem Solver:
  • 3 Answers
Logitech but expensive
Posted on Oct 07, 2008
  • 905 Answers
You will need to compare remotes that support the important features that you want to use
Optical inputs
You have to re route the sound from the samsung to the optical output. You do this is the audio setup section of the setup menu.
Jan 23, 2014 | Pioneer VSX-D498 Receiver
New subwoofer
You will probably have to get the remote. You can search online as there are a number of vendors who sell replacement OEM remotes.
Dec 11, 2013 | Pioneer VSX-D498 Receiver
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
Tried to turn the volumn down but it would not instead it went up had to use the remote to turn the volumn down plus i do not get a equal balance with my speakers rear center is always the loudest and I...
volume up not down is not normal there is a problem with the variable resistor (volume nob) every thing else is normal thats dolby certain sounds make them louder where as other sounds make them quieter it helps make you feel more emersed in the audio
Jan 11, 2011 | Pioneer VSX-D498 Receiver
No remote and want to reset the sound
youll have to try and poke your way through the menu with the front panel buttons. good luck
Feb 11, 2010 | Pioneer VSX-D498 Receiver
MY PIONEER VSX-D498 DIGITAL SIGNAL PROCESSOR BECAME HOT AND BLEW. HOW DO I FIX IT?
As with anything, diagnosis comes before repair. It needs a hands-on pro to look at it.
Feb 03, 2010 | Pioneer VSX-D498 Receiver
VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Dec 22, 2007 | Pioneer VSX-D498 Receiver
Pioneer VSX-D498
Sounds like the on board computer (micro-processor) is waiting for a process to happen and when it does not happen then the unit times out and shuts off. Could be a mechanical or electrical process. Good luck.
Mar 23, 2007 | Pioneer VSX-D498 Receiver
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
Pioneer VSX-D498
silly Question John?? Have you or anybody changed modes on the reciver??? Not so silly as i've seem even a power do that. if not in the system then try unplugging for 24 hours and starting over again . let us know as maybe we can come up with more as we get more info. Good Luck
Pioneer VSX-D498 Receiver Logo
267 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
