Question about Mitsubishi WD-52725 52". Rear Projection HDTV
WD-52725 Jumping picture
Saw alot of your posts, thought you could help. I have a jumping picture on this model. The picture just jumps up and down, like shaking. Got any idea's. I did replace 2 1000uf 16v caps that were swelled up on the power board with no help. Thanks.
  • pcparts1001 Sep 28, 2008
    went deeper, found a total of 8 more 1000uf 16v caps on 3 different boards. That fixed the jumping picture. Thanks for your help.
  • 927 Answers
Good Day;
Sounds like you may have a bad Format Board.
Good Luck, big IRISH.
Posted on Sep 28, 2008
Belt keeps jumping off the front pully
need to know make, model ,year of the chain saw that has a front pulley and a clutch
photos would be a big help in your next post
you are in the chainsaws catagory
Sep 02, 2016 | Garden
Going down the highway at 55-60 mph I just barely tap the gas and the vehicle jumps, I press the gas hard and it stops, leave off the gas check engine light blinks and jumping continues.
A blinking light usually means exhaust system probably catalic converter. You most likely have a small blockage in it which means exhaust can't get out correctly. Have vehicle scanned at autozone or similar.
May 06, 2016 | 1998 Ford Expedition
My saw will not tilt fully, it keeps jumping the gears. I have cleaned all areas, i have checked for foreign objects jamming the saw but cannot locate the problem.
Make sure the inner ring on the locking lever has not loosened up allowing it to apply some gravity pressure and is trying to catch.
this happened to me...i could not get the blade to tilt very far and it started "clunking" inside the saw when i got just "so far". It sounded like it was "jumping a cog". I checked everything, a allen wrench" would tighten. Even outside heads on the cabinet . Sprayed everything with silicone. At the end of trying everything, checked the "lever" behind the wheel where you adjust the saw blade up/down (left turning wheel) and accidently discovered the lever had become loose and was tightening just from weight of the lever alone. I loosened the tension fully and the tilt works correctly now. No jumping. Dumb Luck discovery.RGS in Kentucky
Oct 13, 2011 | Hitachi C10FL 10" Stationary Table Saw...
Hi, this tv is driving me nuts. I just had the bulb replaced because it was jumping and going out. I thought this would solve the problem of the jumping, but is still does. Any ideas on what it could be?...
Tv have jumping picture and go out are not the projection lamp problems."Jumping" Horizontal or Veritical high votage area circuitries have dead parts,must hire a tv tech. to trouble shoot and replaced parts to solved "H" or "V" hold tv to work.Tries many tvs shops,tries get the prices best qoutes and get it repair.
Feb 05, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Jumping picture on Toshiba flat screen model 36HF732
see ur proplem is u hit up or down or previous to much and it thinks ur still pressing it if u have a bos just turn it around and hit reset beleive me its happened before
Mar 26, 2009 | Televison & Video
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Picture on my Bose Lifestyle 35 is jumping around
Hi
Replied you on premium post as well.
Please change TV color system to AUTO to see jumping free picture.
If Bose is either on PAL or NTSC color system, TV will show correct picture and color automatically.
Feb 08, 2009 | Bose Lifestyle 35 System
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
188 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
