I have a sony kp-46wt500 projection tv. the colors at the top and bottom of the screen seem to be separating giving it a 3d effect.
  • 10,594 Answers
Your TV Sony KP-46W500 has problem of convergence ICs mounted on D Board and you need to replace them. Also check related resistors should not be open.
Circuit code is IC8001 & IC8002, part name is STK392-560 and part number is 8-749-019-08
If you need further help, let me know.
Posted on Sep 12, 2008
Picture seems to bend in to the center of the sceen , also if there is A word like live on the screen it is A 3d look , with the writing doubled in A differnt color . I love my tv, help me
The convergence chips (two in this model) will need to be replaced and the set adjusted.
It can be a do it yourself repair if you know how to solder.
Aug 29, 2011 | Sony KP-46WT500 46" Rear Projection...
It's hard to describe...And I'm french speaking but I'll give a try. Now, I see kind of a deformed U-picture... And all the colours are separated... It looks like a 3D shot without the lens. Somebody...
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Sony KP-46WT500 46" Rear Projection...
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
Distored picture
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 03, 2010 | Sony KP-46WT500 46" Rear Projection...
Convergence issue
You need to replace both STK392-560 convergence ICs and some of the 4.7 ohm 1/2watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions.
Jul 23, 2008 | Sony KP-46WT500 46" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Color is messed up
sounds like bad convergance ic
Dec 14, 2007 | Sony KP-46WT500 46" Rear Projection...
Well after rechecking everything again and did some checking with help of some other emailers, I found a blown fues on the G board, that should fix my problem and maybe some others.
Nov 01, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony TV KP-46WT500
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from . It includes replacement coolant,step by step instructions, support, etc.
Jan 14, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
