Question about HP Office Equipment & Supplies
I am having continual problems with black printheads for the HP K550. I am on my third replacement from HP and the black ink still will not print. Ink doesn't even flow out of the new printheads when cleaned manually.
  • 1 more comment
  • wascally2004 Sep 13, 2008
    All the firmware upgrades have been made. This is a K550 and being used as a network printer. The operating system is XP on one of the computers and Vista on the other computer. The printer does not work from either location.
  • wascally2004 Sep 14, 2008
    The printer has a network cable. When I first got the printer it worked fine until the printhead went bad. None of the three "free" warranged replacement printheads have received from HP over the past 45 days has worked in the printer for more than 20-30 pages. When I do the manual printhead cleaning process very little or no ink flows from the black side of the blk/yel printhead.
  • yogesh02 Apr 10, 2009
    problem of continous calibration in hp lj 3600n
I have had this happen a couple of times and have cured it easily. It has only happened with the black with me. It seems to be caused by air in the ink feed line. With the printer switched on open the top cover and hold the resume button for 5 seconds. The printheads should move to the left and you may be able to see air in the pipe(s). Remove the printhead of the offending colour(s) then insert a syringe with the plunger fully down into the rubber that the printhead connects to. Draw up the syringe plunger to draw ink/air through until you can see no more air in the pipe. Replace the printhead and close the cover. The printer should now do a calibration with the offending colour hopefully now working.
Posted on Mar 29, 2009
    Guru:
  • 859 Answers
Do you have the K550dtn or K550dtwn versions or just the K550? You can normally find this on the back of the printer on a nameplate.
And, what operating system are you using?
Thanks.
Regards,
Worldvet
Posted on Sep 12, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Sep 12, 2008
    Do you know if the firmware upgrade as been applied to your printer or not? If you do not know what a firmware upgrade is tell me that too using the comment box below.
  • Glenn Rogers
    Glenn Rogers Sep 13, 2008
    Alright, you have the dtn version then.
    WV
  • Glenn Rogers
    Please verify the model number and version from the sticker on the back or on the bottom of your printer and not rely on what is labeled on the front. This is important as there are different drivers for the different versions.
    Since you stated you printer is networked, do you have a network cable connected to the printer? Or, are you applying a Share to the printer in your PC?
    The dtn has a built in network card and a socket for a network cable.
    The dtwn is wirelessly networked.
    Thanks in Advance,
    Worldvet
HP Officejet Pro K550 - Printhead Error Message on new printhead - cleaned printhead, contacts... tried all fixes... what now? Is it faulty?
I have the same problem. I replaced both printhead cartidges. The MC light stopped blinking, but the KY light kept blinking. I thought it was a faulty new KY ink cartridge. So I returned that cartridge and got a new one. Still the same issue. I called hp and they said the print head is bad now and all they focused on was trying to sell me a new printer. UG! I also heard wiping off the printhead with a dry cloth may help. Did you get yours to wokr?
Jan 27, 2011 | HP OfficeJet Pro k550 Printer
My HP Officejet pro K550 is only printing the first few lines of my document, then it just stops, does not even return the paper???
This is normal for this model of HP printer when the ink has 'expired'.
Normally it will print one line from the print head, then check to see if the ink is okay before pumping more ink into the printhead. If it has expired then it pauses in the middle of printing to give the user an opportunity to replace the ink cartridge with a new one, highlight which cartridge needs replacing by lighting and indicator over the 'bad' cartridge.
There are three solutions for this:
  1. Buy a new HP Ink cartridge;
    expensive and innefficient, but it will ensure the highest level of quality and continued warranty for your HP printer. And is the least likely to cause problems.
  2. Buy a third-party "refillable" ink cartridge, or MOD chip;
    Less expensive, but still wastes what remaining ink you have in that ink cartridge. Voids the warranty for your HP printer and can lead to a print head clog.
  3. Set your system clock and print like it's 1999;
    Silly printer driver reads the system time to determine if it has expired; will cause the printer log to be inaccurate, and cause problems with software updates, security certificates and other time-sensitive applications. May requirie shutting down both PC and printer simultaneously to be effective.
  4. Crack/Patch or replace the printer driver to remove expiry;
    3rd party replacement drivers are unable to match the resolution of HP's original drivers because they don't know HP's secret PCL codes. Cracking/Patching HP drivers may be illegal depending on where you live and what security clearance you have. It may also possibly sometimes break features like document control and printer logging.
  5. Buy another printer
    Expensive and wasteful.
I'd reccommend option 3 if not for the fact that there is no publically availble patch anywhere on the internet. However... you can make any choice you please.
Aug 02, 2010 | HP OfficeJet Pro k550 Printer
While printing multiple copies in black the printing starts fadding after the first copy and gets worse, after 4 copies you can know longer see the printing. I thought it was the cartridge but it still...
That machine is very problematic. See reviews on Google. If your using HP ink then just save yourself the grief and replace the machine. if you have generic ink cartridges in the printer, replace them with OEM. Also, replacing the Printheads may fix the problem. Printheads and Ink cartridges both only have a 1 year shelf life. If they are out of date (date is stamped on them). Replace and retry.
Jun 25, 2010 | HP OfficeJet Pro k550 Printer
Ink cartridge installed but cartridge light continues to blink
Have you only replaced the magenta cartridge, or have you also tried the print head. A bad print head can cause the ink to read as empty or clogged.
Mar 15, 2010 | HP OfficeJet Pro k550 Printer
Trouble with Designjet 110plus: Cannot get Cyan or Black to print. When I change the printhead, the machine does not recognize it for both black and cyan. Machine DOES NOT show error on any printhead or...
Hi Paula, first of all, take out the Continuous Ink System. Second, make sure that the new printhead are good and work propretl, try to get them in another HP 110, if their work good and at your HP not working good whitout your Continuous Ink System replace the carriage assesmbly, but before that verify tge tubes of ink. Good look
Aug 03, 2009 | HP Designjet 110plus nr InkJet Printer
K550 air in ink feedlines
Jan 22, 2009 | HP OfficeJet Pro k550 Printer
How do I clean the printer heads for the HP K550
1. Remove printhead for offending color.
2. Soak printhead area in 1/4" of warm water for about one minute.
3. With a dry paper towel lightly wipe the printhead length wise.
You should get two continuous color bands either black/yellow
or cyan/magenta.
4. Repeat steps 2 & 3 until you get two continuous color bands.
5. Replace printhead in printer print several blocks of each color.
6. Repeat from step 1 until it works.
7. all else replace printhead.
Jan 13, 2009 | HP OfficeJet Pro k550 Printer
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
Sep 17, 2008 | HP OfficeJet Pro k550 Printer
K550 printer not printing Black
hi there is a simple solution to your problem take out the print head place just the jets( where the ink comes out) in warm water for a few seconds while it is in the water use a syringe over each breathe hole at the top of the print head (one at a time) and lightly push air into the head. this process clears any ink clog and frees up the print head and allows it to print propely
Jan 25, 2008 | HP OfficeJet Pro k550 Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
403 people viewed this question
Seeker5211
Seeker5211
