Question about Ricoh Aficio SP C811DN-DL Printer
Error occurred SC285
My printer prints black pages perfect, when attempting to print color my yellow is out of line by 2 mm, so I can not print green , orange, or any color that needs to be mix with yellow, I have bought a new set of drums and a transfer unit and the problem remains the same.
When you try to calibrate through the menu, it fails and this message comes up,error occurred sc285, functional problem, turn main power switch off then on if error appears again, call service.
it there a way to manually adjust the yellow color by 2 mm left or right, has any one experience this sort of problem before how was it solved.
please email me a link that I can get a service manual download.
    New Friend:
I have the same problem except that all colors except black are offset. Anyone find the answer yet?
Posted on Jul 31, 2014
I'm having the same exact problem. Has anyone come up with the answer to this issue? Our printer was dropped a little and hasnt worked quite right ever since.
Posted on Apr 01, 2010
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Printing stops on its own after printing a couple of pages. 2. Printing has yellow overlaps. Have changed the PCU after printer signalled change. Have rebooted, and checked correct replacement of...
SC285 is a line position adjustment error. It is possible the ID sensors are dirty. In order to get to them you have to remove the PCUs and developers as well as the transfer belt assembly. The sensors are behind the shutter that is next to where the upper most PCU would be inserted.
Mar 11, 2011 | Ricoh AFICIO SP C821DNX 50 PPM 4X550 SHEET...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My copier prints fine than suddenly a line will print very lightly then the next line is fine
It will be extremely difficult to provide any solid trouble shooting tips not knowing the type of copier (Manufacture’s model number) or the type of technology that your copier is using (Laser vs InkJet).
I can offer some common logical trouble shooting which I hope will assist you in your fault isolation process.
1. Is there ‘pattern’ to the ‘light line’ symptom?
  • Same location on each page then it occurs?
  • Is the number of pages between occurrences the same?
  • Occurs on text only; Occurs with graphic material
  • Is it a ‘full’ line or part of the line?
2. Does this occur with both Black/White and Color print outs.
  • Some software applications will use the color cartridge to print the color Black as oppose to using the Black ink cartridge.
3. Does this occur when using a specific application?
4. Are you able to determine a MTBE (Mean Time Between Events)?
  • If so, then you can reproduce the symptom and attempt to isolate some of the variables I have listed above.
Again, we need to know the make and model of the unit in question to be more specific.
I hope this helps,
RojoSho
Jan 07, 2010 | Office Equipment & Supplies
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Ricoh Aficio SP C811DN-DL Printer Logo
813 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
