Not a problem just a question about the AV cables infront of my Magnavox 29"?? TV. Can I connect like the small speakers in there to give the tv theater sound?
    Problem Solver:
  • 8 Answers
The front av just input no output
Posted on Sep 12, 2008
Hitachi tv C 29 f 300Bdifferent cable jack on the back iRig my cable to it I have a good picture no sound what can I do
Check the audio settings to your TV first. If the audio is muted, or set low, there will be no audio. If there is audio with ariel signal, and audio is absent when connecting the AV cable, check it with a new AV cable.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 05, 2014 | Televison & Video
I have an old magnavox tv and am trying to hook up a magnavox dvd player but there are no hookups in the back. It is a model #RR254oA 102, Ser# 13610889 purchased in 1992. Can you help me? Sincerely,...
are there any places for av cable to be plugged in? We have an older tv that only plugs in the front. I have a 20" magnavox tv too, about a 1993-94 model And it has the colored (red, yello, white) av plug ins in the back. Yours doesnt have this? Please reply.
Sep 03, 2008 | Televison & Video
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Right speaker doesn't work
Does this happen when watching TV or DVD?
Is your TV connected to a cable box?
Are using AV 1,2 or which source?
Make sure audio cables are inserted all the way.
Audio balance on TV has to be in the middle for both speakers to work.
N Sabre
Nov 07, 2009 | Zenith R40W46 40" Rear Projection...
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Hi how are you going im
Try new/different cable, if still have problem? You have a loose connection in the unit on the connector.
Feb 23, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
