Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Error 41 is on display window
I understand this error 41 indicates that the printer head needs to be replaced. Even though I purchased the machine on Nov. 30. 2004, I rarely use the printer. Sometimes a month or two goes by before I use it and then it is only to print a recipe or one item off the computer. I am almost computer illiterate so I don't use it very much. Please advise me if there is any I can get help with this problem . Thank You
minniemouse.18@netzero.net
  • 4,041 Answers
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Mar 01, 2010
Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Thanks
proton
Aug 06, 2008 | Brother Office Equipment & Supplies
Printer/copier does not work.
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usually just after warranty has expired!
Feb 04, 2009 | Brother MFC 5100c InkJet Printer
Help me solve machine error 41on my brother mfc-3420c.
Hi there
Dec 16, 2008 | Brother MFC-3240C All-In-One InkJet...
Fax machine says error 41 unplug and call brother.
unplug all the connections and reconnect everything back.also checkout for any blocked paper or any paper jam.also remove and check out the cartridges from the printer and reinsert.either its the internal circuit failure error and has to be repaired to make it proper. thanks.
Dec 15, 2008 | Brother IntelliFAX 1800C All-In-One...
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Office Equipment & Supplies
BROTHER MFC 3420C
Aug 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3220C
Error 41 is Print head needs to be replaced, on this model it is not a big job, Heads can be purchased from Brother dealers, ring brother to locate if you wish to repair this machine rather than replace it.
Head sells for about $80 for the part from a brother dealer 1-800-284-4329 and it will need a new set of inks too, not really worth it just replace with new machine with ink and a warranty.
Very common issue, brother extended warranty for this fault for two years but yours would be past it by now, the s/n tells of build date, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06.
I beleive that this is a result a lot of the time by the use of refills and remanufactured ink cartridges being used.
There is heaps of info on net regarding "error 41".
Nov 15, 2007 | Brother MFC 3220C All-In-One InkJet...
Brother MFC-3220C plane paper fax
unfortanatly error 41 means that the printer head needs to be replaced. Got this from the horses mouth. I called the internnational tele # at 1-800-284-4329 and they told me you would need to take in the machine to have this repaired. You can look in your book for a # to find a servicer or go to http://www.brother.com Good Luck
May 12, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
