Question about HP PSC 2110 All-In-One InkJet Printer
Priner doesn't want to scan, copy, or print
Every time i turn the printer on the scanner part makes noises and when i try to print copy or scan it won't do anything except for make the same noise. it sound like the light of the scanner keeps going back and it can't stop.
  • 513 Answers
The only thing I can really suggest is that you reinstall all the software. If it persists you should get in touch with HP, use your warranty if valid. On uninstalling and installing the software: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=79488&lang=en&docname=bpu05205 Good luck
Posted on May 14, 2006
  • 215 Answers
Have you by chance removed the scanner's transport screw. Under the unit you'll see a large plastic screw, make sure it's not in the transport position. It's used to stop the light mechanism from moving during transit. Switch it to the other position and the problem should stop. BMW
Posted on May 15, 2006
SOURCE:
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Screen saying scanner error
You can try uninstall and install printer driver or try a known good connectivity cable.
Dec 13, 2012 | Canon MX310 Office All-In-One Printer
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
We have a priner HP CM3530fs that every time we try to scan, or copy something, it says "Scanner Failure". The code is 30.01.45. I looked up information on this and it said it was due to the copy...
The error code 30.01.45 as listed in the Service Manual call for replacing the SCP(scanner control board).
Call for service, if it's under warranty, call HP.
Jul 26, 2011 | Office Equipment & Supplies
Does hp 1610 priner scanner have a fax capability?
I'm Sorry to say that PSC 1610 has no fax feature
P-Print
S-Scan
C-Copy
Regards
Riztech
Sep 27, 2010 | HP PSC 1610 All-In-One InkJet Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
How do I use te scanner?
Using the scanner is rather simple. First install the included software. If you are running Vista, then you need to download an updated version of the software. Open HP Solution Center then go to scan. it should scan the page (make sure the printer is on first). Another method would be to press the scan button on the bottom of the printer's control panel. To copy a sheet, simply press either the black and white or colour tab in the control pannel of the printer. You can select the type of paper above and the amount of copies to make as well.
Hope this helps!
Jan 19, 2008 | HP Deskjet F335 All-In-One InkJet Printer
HP PSC 2110 All-In-One InkJet Printer Logo
185 people viewed this question
Clive
Clive
Thomas F. Schneider
