Question about Bosch Washing Machines
Our brand new bosch exxcel washing machine is jumping all over the place. We have checked it with a spirit level and it is level. The feet are tight. The washing is loaded level. What is wrong ?
  • 1,239 Answers
Hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt.
Posted on Sep 12, 2008
I leveled my machine but t jumps badly
my answer it maybe not the answer you want !
watch if the clothes have made a bundle on one side ?
a washing-machine Too full stop the spreading the clothes evenly ,,
but if a front loading ,
the four rubber feet must touch the floor evenly ,
look for the two front rubber feet are level and push hard on the top to level the back legs automatically or adjust them manually !!
Oct 04, 2015 | Bosch Washing Machines
Why is it out of balance?
One of the feet is not in proper contact with the floor. All the feet are adjustable in height. The washing machine must be checked level, front to back and side to side using a long spirit level. All feet must be in equal loading contact with floor.
Regarding loading, a small load can often be worse as all the clothes end up on one side. Run a cycle empty and see what happens? Run a cycle full of towels, 3/4 fill the drum and see hat happens?
Finally, is the machine new? Did you remove the locking bar inside. If this is fixed in place there is no dampening from the floating springs and shock absorbers. I did that once after a move!
Jun 30, 2015 | Admiral Washing Machines
What does the reset on the load level do?
its telling you that you have put to much washing in the machine or the machine is not level place spirit level on top of mache and adjust feet accordingly
Sep 28, 2014 | Amana Washing Machines
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
My washing machine shakes during spin mode
The machine must be level or it will shake. There should be feet under the front which screw in and out. Get a spirit level and adjust the feet so it is sitting level front to rear and side to side.
Also make sure it isn't rocking slightly when it's not running - if so screw out one of the feet till it's steady. If you don't have a spirit (bubble) level compare how vertical the sides are to the wall/cupboards etc. However a level is best as even a little lean can make it shudder.
Or your putting too much washing in it!
Feb 07, 2013 | Whirlpool Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
How do i balance my bosch front loader moves all over the place
Idealy ,you need to make sure that the machine dos not jump all over the place , this involes adjusting the front feet could use a spirit level doing it well to adjust the levels across and front to back.....
Jan 07, 2011 | Bosch Washing Machines
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Washer is on wood floor and when on spin cycle it jumps all around.
hi pat
try adjusting the feet and use a spirit level to ensure the machine is totally level and this problem should disappear
Oct 28, 2008 | Washing Machines
Washing Machines Logo
301 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
