How to use a usb cable for the psp - Computers & Internet
  • 6,487 Answers
Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
Scroll to the "Settings" icon on the home menu of your PSP.
Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
After that you can now transfer file from PSP to computer and vice versa...
Hope that helps..............
Posted on Sep 12, 2008
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
May 24, 2012 | Sony PlayStation Portable (PSP) Console
About music
conenct the PSP to USB and then set it to USB mode.
access your "my computer" then clcik on the PSP icon on your my computer screen
you will be able to see folders in there, one is music, just copy the music file from your computer then paste it in the "music folder in the PSP.
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
My usb cable will not charge my psp
Are you plugging the charging plug into the PSP?There are two plugs on the USB cable 1.the USB plug. 2.the charger plug itself. The USB cable looks like the other end that plugs into the computer only smaller.The charger plug looks like the ordinary AC adaptor.
Also note that You need the computer/device that the PSP is connected to,must be turned on,well this is true with mine anyway.
Also the USB does not charge the PSP as fast as the AC adaptor.
Oct 02, 2010 | Sony PlayStation Portable (PSP) Console
I cant charge my psp with usb
go to settings and check that usb charge option is on... and ake sure its in usb mode
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
Computer can't detect my psp
If you know someone who has a USB data cable for PSP, please borrow and test it with your PSP. USB cables has 4 wires, 2 for power (+5V and GRD) and 2 for data (+ and -). With PSP, the power and data wires are separated and has different input on the PSP, if 1 of the data wires is damaged, it will look like the cable is ok but it couldn't transmit and receive data properly. In your case, I think your PSP is can transmit but couldn't receive a reply from your PC.
Let me know if the borrowed PSP USB cable don't work.
Apr 07, 2009 | Sony PlayStation Portable (PSP) Slim...
Do not know how to copy songs from computer to PSP
Connect he PSP by USB cable to your computer. On the PSP , Go to Tool column, and scroll to USB, then click X. You also need a Memory card in your PSP. One the USB is activated, you should be able to find your PSP memory card folders with your computer. Copy the music files from your computers folder to PSP/ Music folder on the PSP memory card. Then disable USB on your PSP, the remove hardware on the computer before disconnecting the USB cable.
Dec 29, 2008 | Sony PlayStation Portable (PSP) Console
Psp homebrew FuSa
the cable you are describing is the A/V cable. it is used to display the PSP on your TV.
the cable you need to connect the PSP to a computer is a mini-b USB cable.
just go to a store and ask for a USB cable for your PSP.
Nov 22, 2008 | Sony PlayStation Portable (PSP) Slim...
Psp
Follow this steps to transfer music on PSP:
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how much music you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. Create a folder called "PSP" on the PSP Memory Stick (if there isn't one already) -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. Create a folder called "MUSIC" inside the "PSP" folder.
  8. Drag and drop image files into the "MUSIC" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Going online
uhh, i don't want to sound sarcastic by this - but the PSP is NOT designed to go online with a USB cable.
The USB cable is used to transfer files to and from the PSP console. You can use it for charging the PSP (Slim) if you don't have a charger with you handy.
Other than that, you can't use the USB cable for anything else.
Apr 06, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
