Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Freezer door will not open!
My mother-in-laws bottom freezer door will not open. In fact, she pulled on the handle so hard, it detached from the door front.
I tried to open it, but it's stuck on the right side; the left side will pull away about an inch, but the drawer will not slide out. At first I thought it was mechanical, but a local repair shop advises that is not possible (they can get out to her house for 4 days).
Any suggestions?!?
  • a1949vintage Sep 12, 2008
    I did as advised; however, the gasket was not sticking to the frame of the refrigerator. That said, I did fix it!
    Here's my theory ... I believe my mother-in-law did not close the freezer door completely. Frozen items start to melt, water traveled to the metal door glide, then ... when the door was eventually closed, the water froze and the glide froze in the closed position. I gave the door a hard "yank" and it opened about 10" ... far enough for me to lift the door completely out. I then filled a spray bottle with very warm water and sprayed the glides. The ice melted, and the glides then began to function properly.
  • Kenmore Master
  • 5,568 Answers
Something has caused the gasket material to adhere; either the material from which the gasket is made or a spill of something sticky that has dried. If you can get a crack to open anywhere, slide a butter knife into it and wobble or rock it while applying a little pull to the door.
Once opened and cleaned, treat the seating area for the gasket with silicone spray from an auto parts or home improvement store. I wouldn't spray it on the surface but on a clean rag to wipe the gasket seat; the volatile carrier of the spray may damage some paints or plastics.
Posted on Sep 12, 2008
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Tip
How to remove a front right door panel concorde sedan four door 96
How to remove a door panel, first u must open the door and unscrew the screw that is in the door handle then with a flat head screw driver unhook the plastic conectors to the cover of the handel becarfull not to pull to hard gently pull it as needed then pull the door handle as if opening and then pull the cover of handle out wards and then un detach the electric conector for the door locks then on the bottom handel unscrew the screw that is in the handle then pull out the case that holds it. then unscrew the screws that are on the inside towards the interior of the car there are two then two on the bottom then on the side that opens there should be on or two then pull the panel upwards and then towards your self you should be able to also detach the electric conector for the windows then when your done fixing it the instalation is reverse make sure that you conect the window and door lock conectores and make sure that the door falls in place with window latch. good luck buudy.
on Aug 22, 2010 | Dodge Intrepid Cars & Trucks
How to, removing front right door panel on 1996 concorde chrysler 4dr sedan
Aug 16, 2010 | 1996 Chrysler Concorde
How do i tighten miele refrigerator door handle
grip slide on side of door handle and pull door handle to open position slide will detach from handle exposing 4 torx screws tighten screws and refit slide
Apr 29, 2010 | Miele KFN8462S Bottom Freezer Refrigerator
Freezer handle falls off on one side , kenmore elite - pull drawer freezer
Mine does that too. I've simply accepted the fact the the screw holding the handle on just loosens over time. Periodically, when I feel the handle becoming loose, I tighten it with an allen wrench and go on.
Feb 21, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer door hard to open for about 3 minutes
This is normal and nothing to worry about. The warm air that enters the freezer when the door is open simply cools and causes a pressure drop in the freezer whioch makes the door hard to open for a while until the pressure equalises. It at least proves that you have good door seals!
Sep 10, 2009 | GE Profile¿ 42" Built-In Side-by-Side...
The bottomw freezer door on our Amana refrigerator won't open
Let it thaw, just like you're doing. Afterward, the door will open. You might be able to speed the process with hot water and a turkey baster. Beginning at the top of the door, take the business end of the baster and stick it between the door gasket and frame and squeeze. 'Course this will make a mess, but you won't lose the food that's in the freezer, right?
Write back and let me know what you find when you get the door open. Like was there a slab of ice on the freezer floor? Frost build up on the wall? Stuff like that. It'll help me figure out what caused this.
Another thing, when you write back, include the model number and manufacturer number (These are listed on a sticker inside the fridge). With those numbers, I can look up a door handle for you.
SG
Mar 25, 2009 | Amana ABB1927DE Bottom Freezer...
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
408 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
