Question about Samsung CW29M64NS 29" TV
Help needed with Samsung Plano 29" TV - Model No. CS-29Z6HF
I was trying to adjust the geometry of the screen after I entered the programming menu (through the "Display - Menu - Mute - Power" combination) and I accidentally selected some option and know I can see the word "AGING" written near the bottom left corner of the screen permanently.
The TV doesnt go into standby mode anymore and I have to manually power it off. This also means that I cant enter the programming menu again.
Can someone please help me with this? Many thanks.
(Note: the model of the tv is CS29Z6HF and NOT CW29M64NS.)
SOURCE: want DEFLECTION SETTING for my samsung plano 29
I need the deflection constant from Samsung factory for adjustment TV Samsunng Plano of me.
Posted on May 18, 2011
SOURCE: Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Posted on Oct 05, 2007
SOURCE: Samsung LCD TV LN40A650 - Service Mode
1. Turn off the TV
2. Press "info" then "Menu" then "mute" and then "Power" on your remote (As fast as possible).
The TV will now start up in Service Mode
Breinholm / Denmark
Posted on May 24, 2008
Shuttle83
  • 1139 Answers
SOURCE: samsung plano tv
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 25, 2008
  • 317 Answers
SOURCE: plano samsung tv dvd combined
try 0000 reset
Posted on Aug 03, 2008
Panasonic 29 crt tv problems with the geometry
If there is a picture geometry problem, you have to check its Pin Amp section circuit inside the circuit board for any damaged component/s. If this section have any fault, the picture geometry will be distorted. Before adjusting the picture geometry after entering its service mode settings, you have to check this section first. If you want to know how to enter the service mode option window to this set, check this link.
Jan 27, 2013 | Panasonic TC-29P22R 29" TV
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
When I put on my Samsung Plano TV (Model is CS-20M16ML) the picture display after sometime becomes problematic. The blankness appears at the bottom of the screen and then gradually goes up and up thus...
Vertical output IC has the fault. Try this site named "Electro-help". You might get details from here. Type this name in google search box and click enter.
May 01, 2012 | Samsung WS32Z308P 32" TV
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
Want DEFLECTION SETTING for my samsung plano 29 inch gigabass tv
Nov 08, 2009 | Samsung Televison & Video
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Zoomed screen on my TV
with remote control use Zoom boton, or enter to menu and seek for this option.
Oct 23, 2008 | Televison & Video
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Samsung plano tv
I hope this helps
Thank you,
Shuttle83
Dec 04, 2007 | Samsung WS32Z308P 32" TV
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Samsung CW29M64NS 29" TV Logo
752 people viewed this question
Jerry Greenberg
Jerry Greenberg
