Question about Emerson MW8107WA Microwave Oven
I NEED A ELECTRIC DIAGRAM
THE LAST TIME I TOLD YOU ABOUT MY PROBLEM WITH MY MICROWAVE EMERSON. IM A ELECTRONICS TECHNICIANS BUT I HAVE THIS PROBLEM I MADE A DIAGRAM AND I FOUND ALL THE CONNECTIONS START THE FAN WHEN I CLOSE THE DOOR CANT USE IT I WANT TO KNOW IF THE TROOBLE IS WITH BAD CONNECTION IN ONE SWITCH? CAN I CHAT WITH YOU? WHEN? I HOPE YOUR ANSWER. SEE YOU LATER
This is what i think: There are two interlock switches in most micro's. Ones for the fan and ones for the magnatron and the transformer. The one for the fan can also control a lite. These micro switchs have a "n"ormally "o"pen position and when they are switched the normally open side closes there for turning on the cuircuit board that then switches on the fan,transformer ect. ect. Two test these switches simply look at the switch and you will see a "c." by one of the connections, That stands for common. Put one end of the ohm meter there. Next you will see "n.o." that stands for normally open so put the other end of the meter there and you should not get any reading. Next push the lever down and then the meter will give you a dirct short reading and should have no resistance at all and if it does measure even a few ohms that switch should be repalce as Ive seen these faulty switchs break down when current is on them and causes all kinds of intemittant connectins. Now with the other connction on the switch if there is one will have a "n.c." by it and that stands for normally closed. With the meter still on the 'c' connection put the meter on the nc without pushing on the switch. It should read a direct short also with no resistance. Now while holding on both same connections push down on the switch and it should not show anything as its wide open with no measurement at all. If it dosent do this then the switch is bad. Now almost every microwave made, there is a wiring diagram inside the outer cover. If its not there you can order one from the company but most micro's are almost all wired the same.
Posted on Feb 27, 2008
    President:
  • 3,130 Answers
Sure man NO Problem. There are two interlock switches in most micro's. Ones for the fan and ones for the magnatron and the transformer. The one for the fan can also control a lite. These micro switchs have a "n"ormally "o"pen position and when they are switched the normally open side closes there for turning on the cuircuit board that then switches on the fan,transformer ect. ect. Two test these switches simply look at the switch and you will see a "c." by one of the connections, That stands for common. Put one end of the ohm meter there. Next you will see "n.o." that stands for normally open so put the other end of the meter there and you should not get any reading. Next push the lever down and then the meter will give you a dirct short reading and should have no resistance at all and if it does measure even a few ohms that switch should be repalce as Ive seen these faulty switchs break down when current is on them and causes all kinds of intemittant connectins. Now with the other connction on the switch if there is one will have a "n.c." by it and that stands for normally closed. With the meter still on the 'c' connection put the meter on the nc without pushing on the switch. It should read a direct short also with no resistance. Now while holding on both same connections push down on the switch and it should not show anything as its wide open with no measurement at all. If it dosent do this then the switch is bad. Now almost every microwave made, there is a wiring diagram inside the outer cover. If its not there you can order one from the company but most micro's are almost all wired the same. Hope this helps. Good Luck
Posted on May 13, 2006
Emerson Microwave MW9325SL not Heating.
cant give an answer since would need to test those components
Jun 22, 2018 | Emerson Microwave Ovens
How do I find the fuses in Microwave
Mainly there are three/four fuses in Microwaves depend to maker.
First one to be checked it is on plug about 13A in cable out side microwave
Second one for power supply usually comes 10A located in terminal board of cable supply in side microwave if you follow the cable.
Third fuse i think about 5A for high voltage it located usually on wire connected between transformer and capacitor.
Fourth some Microwave have third one on the control board located behind switch panel.
now.
if the second fuse is blowing immediately after starting microwave that usually mean one or more of the following need to be replaced
1- diode
2- HV. capacitor
3- magnatiron
Which only can replaced by skill technicians
THANK YOU.
Oct 31, 2014 | Emerson MW8998B 0.9 Cu. Ft. Counter-Top...
Microwave starts but doesn't give heat
you have the following problems:
1) internal switch 2) high circuit problem 3) control board , i recomend you call to some service tech. see the diagram attached.
God bless you
Jul 14, 2012 | Emerson MW8168B Microwave Oven
Emerson microwave oven MW8102SS smells electric burn while heating food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '
Jun 07, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Emerson 1100 microwave prolonged heating time
the magnatron is going out (this is what warms up the food!( would be cheaper to replace then to fix!)
Dec 09, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8107WA Microwave Oven Logo
210 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
