Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Clean dirty lights
The clean dirty lights stopped working it says dirty all the time
  • 26 Answers
Those lights don't really do anything. It's just something added to make it look more attractive to the seller. There is a small computer board in the vacuum and it's probably dusty. If you take the bottom screws out near the rotating brush assembly and clean it inside sort of dust it off it wouldn't hurt it. But they don't really have the brains in it to say if somethings clean or not.
Posted on Sep 13, 2008
Red "DIRTY" light is on most of time, even after going over and over what should be clean carpets. Head is lifted, getting good suction. Got a solution?
The sensor that detects the dirt can get dirty causing the light to stay on. Hold the vacuum up in the air or position the vacuum in a way to observe the light when the vacuum is running but the nozzle assembly is not on the floor so it cannot be picking up any dirt. If the light will not go off it's likely the sensor needs cleaned.
Mar 09, 2017 | Vacuums
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Z8220 STOPS WORKING HEPA FILTER LIGHT FLASHING & NEW FILTERS INSTALLED
check your hose for a clog, id even check from where brushroll is at bottom to the end of hose. sounds like that could be your problem.
Jan 08, 2013 | Electrolux Vacuums
I have a Bissel Pro Heat Plus and I used it once, one year ago. I may be using it wrong, as my carpets were wet and there was no return (dirty water). If I remember correctly, going forward wets and...
It has only one tank that serves two purposes. It holds the clean water and collects the dirty water, so you only have to empty/fill one tank. If you check reviews of this machine you will see that they basically stop working correctly after a very short time, if I was you I would just contact their customer service at this number 1-800-237-7691
May 16, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
The suction stopped working after emptying dirty water and filling up with new water and cleaner
I have an older Hoover SteamVac Supreme #F5815 and I'm having trouble figuring out how to clean the part in the front that the dirty water goes thru before it gets to the tank. How do I clean it?
Mar 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
No liquid light keeps coming on even though liquid in
did u leave dirty water in there overnight? i did and had the same problem, had to prime the valve a bunch of times, but what did it was irobot's suggestion to clean out the dirty tank several times... there must be a sensor in there that moves and gets stuck with goo...
Nov 03, 2010 | iRobot 5800 Scooba Vacuum
On turning on different noise then noticed smell of burning then just stopped working and no power since. DC 07 Dyson.
Unfortunately your motor had burnt up..most times this is due to not cleaning or replacing the filters...the filters get dirty and the motor gets no airflow to cool it....very common on dyson vacs
Feb 07, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell spot bot
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
I have a feeling is this the solution for most people whose manual mode works fine but, automatic mode stops with lights a' flashing. Why manual still works though is a mystery to me. You'd think all modes wouldn't work then.
Nov 25, 2007 | Vacuums
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
SpotBot: all lights flashing!
Aug 07, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
42 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
