I have a Dell 5200series(Ithink) w/Windows XP -is 5 yrs old - 28GB on hard drive w/approx. 18 GB available.I recently added 512KRAM to go along w/existing 256K RAM - I am on dial up - Ihave used Reg Cure to look for system problems ------ the problem I am having is 1- that it is slow accessing sites- when I get to a site I have no problem interacting and I can have 2-3 sites running at a time -----and 2--- when I turn puter on - I have AOL - the volume says "welcome" but no longer says "you got mail", if I access - say a youtube spot - it will load - but the play back is extremely slow- a 2 min clip takes forever ----- it will play maybe 2-3 seconds of audio/video at a time and then pauseeeeeeeeeeeeeeeeeeeee for a minute or 2 - then 2-3 seconds again - then pause------------if i try to use the music function - same results- access is slow - when a station is selected - 2-3 seconds of music then 1-2 minutes of "pause" then 2-3 seconds, etc. I have tried adjusting my disk space in internet settings from anywhere from 4000MB to 20000MB and same results - another symptom going on in here is if i hit control/alt and tap delete ----- task manager pic no longer comes up but it does delete the task running. Any clues?
    Guru:
  • 558 Answers
Hi 1MLucke51,
Thanks for the posting in FIXYA.
Please can you tell me the Dial up connection speed.
Please delete all Prefetch files, Temporary Internet files, Temp files , and then empty recyle bin.
How to Do:
Step 1: Delete the prefetch files from time to time.
Click on start ..run .. type .. prefetch
ok
Select All and delete
Step 2: Delete temp files
1. Quit Internet Explorer and quit any instances of Windows Explorer.
2. Click Start, click Control Panel, and then double-click Internet Options.
3. On the General tab, click Delete Files under Temporary Internet Files.
4. In the Delete Files dialog box, click to select the Delete all offline content check box , and then click OK.
5. Click OK.
Step 3: Temp Files
Click on start .. run .. type
%temp%
ok
Press Ctrl + A key and delete all files
Note: Skip if some of files not delete and warn by computer.
Then Empty recycle Bin
Regards
Ellin
Posted on Sep 12, 2008
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me
    know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Will only run on 32b windows vista or xp
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Aug 12, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
Which operating system supports IBM thinkpad 600x
All versions of windows except Vista and Windows 7.
You may find it difficult to purchase Windows version up and including XP.
You may need to install more RAM and a a 6 to 10 Gb hard drive.
The smallest hard drive available is approx 100Gb but the BIOS in the Thinkpad won't support a hard drive this large.
Nov 19, 2009 | IBM ThinkPad 600X Notebook
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
Nov 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
WD800U017 passport problem
The drive in the case is broken. You will have to take the drive to data recovery centre to recover your data.
Aug 03, 2009 | Western Digital Passport WDXML800UE...
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Formating hard disk
IF the old PC motherboard will recognize the drive while booting up, Windows 98 will also see the drive after boot-up. You may have to reformat the drive into smaller partitions.
All you have to do is physically install the drive in your old computer and attempt to boot. After the computer boots up, if the drive does not show up shut down and put the drive back in your old computer. Use the manufacturer's partitioning software available on their website to change the drive from one 250 Gb partitions to five 50 Gb partitions.
Feb 15, 2009 | LaCie (300728U) 250 GB Hard Drive
Dell inspiron 8100 notebook
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Jan 20, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
