Question about Sony Cyber-shot DSC-W70 Digital Camera
Video/Still Issue All the settings take videos. How do I get it to go back to taking stills (except for the video setting)?
  • Jen May 11, 2010
    thank you for helping, i forgot that i had changed the settings, and it's my mom's camera.          thank you again
Somehow the setting had been changed to "burst" instead of normal. We stumbled onto the solution by randomly changing the "burst" setting back to "normal."
Posted on Sep 13, 2008
Model: LC-70LE732U Problem: No audio or video. Error code: flashes 1 long, 1 short Tried: Reset to Service Mode: Replug W/ holding Input + volume down Response: solid light for 10 sec, returns to...
According to the information I have on error codes for that set this is a back light issue. Try removing the plugs to the back lights then plug the set in and see if you have normal voltage, if you don't it may be a power supply issue but I think your going to find the voltage is normal with the plugs unhooked and they drop off if they are hooked up, meaning you have at least one bad back light strop
Oct 18, 2017 | Televison & Video
I would like to watch a video in my car but it says warning must set park break & my park break is set but it still won't start.
Pull the stereo out and look for the parking break wire on the back, take that wire and ground it.
Mar 31, 2013 | Car Audio & Video
Can not change video input.
You may want to take a close look at the owner manual as some sets like this one may have a feature that locks out both the remote and the front keyboard except for power on the front of the set .
Apr 23, 2012 | Sanyo Televison & Video
Having update problems took to friends house to try his internet.all i did was unplug 2 cables from the back and took it.got there and had sound but no video.took it home,got video no sound.still no...
This sounds like a connection problem. If you are not using HDMI then you can have some issue with connecting the component cables. The component cables have similar colors. Be sure to connect each one to the correct color on the TV. Be sure not to connect the two for audio into the ports for video on the TV. If you are using HDMI i would suggest while it is connected to your TV, go into settings then video settings and select a lower resolution such as 720p. Then take it to your friends house and connect via HDMI.
Jul 21, 2011 | Sony Playstation 3 (PS3) Console
I have just bought a 42LED5300 TV. However, after just 1 day of watching it, the screen has no picture although audio can still be heard in the background.
Make sure all of your audio and video cables are connected correctly. Make sure you selected the correct imput channel on the set. What I mean is if your watching a video, make sure you have selected the correct channel for the device you are using, either video 1 or2 and that the device is correctly installed to the TV. If you still have no picture, contact the store which you bought this and ask them if there is anything they can help you with, if this doesn't resolve the issue themn by all means take it back to the place of purchase and get an exchange. One day old they should take it back without an issue
Nov 14, 2010 | LG 42LC2D 42 in. LCD HDTV
When i start a play now game the the whole map is black except for the units.how do i fix it?
this is ether a video driver problem of a video card setting problem. so try updating your video card drivers and if problem persists,configure your video card settings.
Jun 14, 2009 | Take 2 Interactive Civilization IV: Beyond...
Video Settings
Hey there,
I remember reading about this in my manual
It's under one of the TIP! sections, on page 46 under the 'Video Camera' topic. It says the following;
  • "When you exit the video camera all your settings will return to default, except Video Size and Video Quality. Any non-default setting you require will need to be reset, for example colour tone and white balance. Check them before you shoot your next video."
Same applies to the Camera settings on page 43;
  • "When you exit the camera, all yours settings will return to default, except image size and image quality. Any non-default settings you require will need to be reset, for example, colour tone and ISO, Check them before you take your next photo."
Hope this helps!
- Ness. :3
Oct 29, 2008 | LG Secret ? KF750 Cellular Phone
Samsung s730 Digital Camera - Video Stuttering Problem
I have the same problem with 640x320 video @ 30fps. The first one was very clean, but after that the video freezes every two seconds, but the audio don't. I "fixed" this issue changing the video format from NTSC to PAL. Now the videos are smooth again, and if you want NTSC playback, just use a video converter on your PC.
Jun 24, 2008 | Samsung Digimax S730 Digital Camera
Long time to power up video
My Sony KP-53XBR200 will not display any video (even from the tuner) except the internal display until it sees a video input on one of the video jacks on the back after a power hit.
I solved this by putting a video cable from Monitor out to Video 4 in (unused for other video). Voilla! Instant video on. This may not be your issue, but it fixed my set!
Oct 20, 2007 | Sony KP-53XBR200 53" Rear Projection...
Camera seems to ignore all buttons
I have the exact same problem. I purchased a new battery, but still have the same issue. Any ideas?
Sep 20, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
42 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
