Question about Nokia 2115i
Failing network I just want someone to tell me how to enhance my network that fails about 8pm everyday. Thanks.
  • Anonymous Nov 05, 2007
    when i select a network selection of network is not availlable
    President:
  • 3,130 Answers
You cannot enane your network if its failing to connect unless you install your own cell Sorry man
Posted on May 12, 2006
Get a differnt phone
Posted on Jul 04, 2007
One practical way is to go to a place where there is a better signal at 8 pm or change your network provider.
Posted on Jan 22, 2008
  • 74 Answers
Dear take it to a doctor
Posted on Mar 10, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
The auto mode isn't working on my zilla digital 24-7 power center, when on auto mode no lights come on?
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Is this a new timer??? Or old timer that stopped working?
Replace battery.
Press reset button to clear all memory traces before programming.
Check programming for overlaps and mismatched day(s) of operation.
Test outlet for correct polarity and grounding using circuit analyzer.
Make sure light bulb is turned ON. Timers do not reach out and rotate on-off switch.
Make sure outlet has at least 80% rated voltage shown on load label. For example 115 volts x 80% = 92 volts
About your specific programming needs:
Zilla selects 12 o'clock as changeover time between am-pm.
So if you want 8:02 to 7:59 operation, then that is under the 12 hours, but it crosses the 12 o'clock am-pm changeover.
Workaround: Shorten your times to less than 12 hours just like you have done.
But set current time differently so 8-8 falls under either am or pm, but does not cross am-pm. The timer does not actually know what the current time is, so simply fudge by amount needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 18, 2012 | RTO Zilla 24/7 Digital Timer Power Center
I need to have an emission test on a honda element 2004 and the drive cycle needs to be done to get the information, I had a battery change and it erased the information
drive cycles are done while you are doing normal everyday driving. the only reason an emission test would fail is if your check engine light is on. a local autozone or advance store should be able to hook there engine scanner up to tell you if any catalyst monitors have failed and check for trouble codes.
Jul 14, 2011 | Honda Element Cars & Trucks
Emachines pc keeps saying hard drive is failing
What kind of resources are you pulling on the pc everyday? For example are you doing heavy writing to the drive everyday such as video editing, ripping etc and how much air flow is your pc getting. If the case gets too hot or warm for long periods of time it can cause the hard drive to fail quickly. Lastly check your power supply male sure its pputting out the proper voltage to the computer specifially the connection to the hard drive. If its not stable the nit will cause your hard drive to fail.
Joe
May 25, 2009 | eMachines W3619 PC Desktop
Belkin Wireless Router F5D8233-4 shotty connection missing wireless
The problem may be that your router needs a firmware update. I work with routers everyday and have found that even out of the box they do not have the lastest firmware. Ditto for linksys.
http://www.belkin.com/support/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
FAILING NETWORK
Hi
in that hour that is peak hour for celphone user in the whole world! millions to half billions of user are using in that hour! the network is so bc! or in short! in the post office you need to fall in line to send your message!!!
Thanks!!!
Jun 28, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Mtu test is failing
I've had the same problem and struggled with it for hours... If your on the Comcast network, there seems to be problems with adjusting MTU. I have a Dell 2350 router and that particular router cannot have MTU modified. Also, sometimes the MTU is effected by computers or phones in the house being on. One more suggestion, try a gaming router. Good ones start at 90 dollars, somewhat expencive but well worth it.
Jun 03, 2008 | Microsoft Wireless Network Adapter Xbox...
FAILING NETWORK AT NIGHT
thats an issue with your service provider If theres no network theres not a thing in the wrold you can do to get service. sorry
May 12, 2006 | Nokia 2115i
FAILING NETWORK
contact your sevice provider as maybe theres an issue with a tower or cell in your area.
Nokia 2115i Logo
187 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
