Question about Apple MacBook Mac Notebook
APPLE MACBOOK MY MACBOOK WONT BOOT UP, THE SCREEN LIGHTS UP AND I GET THE APPLE SIGN BUT IT JUST CONTINUES TO TRY TO LOAD. ANY IDEAS?
  • robertledo Jan 05, 2009
    I have the exact same problem. The only course of action my macbook pro allows me to take is single-user mode, and in that mode it will not allow me to run the "diskutil repairPermissions /" command that was the recommended solution. Any other recomendations.
If you get the Apple logo with spinning lines underneath it but not getting past this stage then the hard disc is being seen but something is failing in the boot process, causing it to stall.
Most likely this is a case of incorrect file permissions which is easily solved.
There are 2 ways of doing it, depending on whether you have an OS X install disc to hand or not.
IF YOU DO HAVE AN OS X INSTALL DISC:
Insert the disc into the DVD drive, power on the Mac on after hearing the chime hold down the C key. This forces the Mac to boot from the DVD. After a few minutes you'll get a screen asking which language you wish to use as the main language; select English or whichever is appropriate for you.
On the next screen the Installer box will appear. Ignore this and instead on the menu at the top of the screen select Utilities -> Disc Utility. Once this has loaded select your hard drive on the left hand pane and then first click "Repair Disc" and once that has finished click "Repair Permissions".
Once these have completed successfully reboot and OS X should load up fine.
IF YOU DON'T HAVE AN OS X INSTALL DISC:
This is a bit more tricky. You have to boot into single user mode. To do this power on the machine, and after the chime hold down Cmd (Apple key) and S together. The screen will turn black and an a load of white text will start appearing and scrolling upward as the system loads. Basically this is what happens behind the Apple startup logo, only in single user mode rather than multiple user mode.
After a few moments the text should stop scrolling and you should see a prompt which looks similar to:
localhost: / root#:
Note that localhost is the name of your computer so will possibly be different to "localhost". At this point type the following EXACTLY including spaces, capitalisation and dashes etc:
/sbin/fsck -fy
now press enter, then type:
/sbin/mount -uw /
now press enter then type:
and press enter. It may take a few minutes to repair the disc's permissions, but once complete you should have the
localhost: / root#:
prompt again. Now type:
reboot
and hit enter. The system will then reboot and should boot into OS X without issue.
Posted on Sep 23, 2008
    Problem Solver:
  • 8 Answers
If the Mac is having major HDD errors it wouldnt boot to the Apple logo.
Last time mine went bad it jams at the first screen the apple logo is normaly pass the normal.
Having it jam at the apple logo I would try to Reseat the ram or at least reset PRAM and or use the reset button on the back depending what model you have.
Posted on Sep 15, 2008
  • Apple Master
  • 5,568 Answers
The Apple logo is probably embedded in a chip; without any sign of an error, I would be suspecting the harddrive. When you first turn it on, listen closely to the end where the drive is located to ascertain whether the drive is irregularly seeking or constantly repeating the same motion. The latter means the drive cannot find the sector it needs to boot.
Posted on Sep 12, 2008
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
2006 Macbook Pro replacement screen problems
You have a bad driver. Reinstall your screen driver or clear your P ram by holding the letters P and R and the control button when you boot your laptop. Hold them until it chimes and reboots.
Apr 12, 2013 | Apple MacBook Pro PC Notebook
My macbook wont start up sucessfully. Once i boot it up it loads up to the gray apply and spins and continues to the blue backround. But other than that it wont go any further. I tried to get it into safe...
If safe boot doesn't work, follow the steps in this article:
http://support.apple.com/kb/TS2570
Worst case scenario you'd need to do an Archive and Install (see how in http://support.apple.com/kb/ht1710) if you're running 10.4 or 10.5, or in 10.6 you can just reinstall the system without having to do anything special.
Jul 08, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Ibook A1005 (2002) model,just wont boot up,I press the power on button,the Apple sign comes up,and it just continues to load with no results!!!!It was working just fine,can anyone assist me
If your iBook loads to the Apple logo with a spinning gear beneath it but does not progress past that point, follow the instructions in the following article to attempt to resolve the issue:
May 18, 2010 | Apple Computers & Internet
My macbook is frozen with the folder icon showing on a blank screen with a question mark on it? Help
It sounds like your MacBook can not find the system software to boot up. This is often a sign of a hard drive going bad. Try booting from the CD/DVD that came with your MacBook and running Disk Utility.
You can also refer to this article:
http://support.apple.com/kb/TS1440?viewlocale=en_US
I hope this helps.
Nov 16, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My mactop wont load from startup to login screen..i simply get the loading screen
please repair your windows it might be currupted. that's why cannot log on screen.
Aug 19, 2009 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
My Macbook Pro wont boot - stays on the blue screen
The fact that the "BONG" sound (or better known as the MAC CHIME) does come on and nothing further means that the computer cannot find your hard drive or (sometimes worse) cannot find the operating system. This means that you will have to remove the hard drive... then insert it nice and firmly again. Try now to boot. If nothing happens then your drive has gone faulty and it could mean that you may have lost your data... NOT NECESSARILY though.... What I mean by that is that you may still be able to access the dat when you connect the "faulty" drive to another computer via USB with an external casing and then get your DATA off it.
Jul 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Blinking file picture w/"?" On blue screen. Will not load OSX.
You could try to boot from the OSX DVD while holding the C key pressed. When you get to the Apple menu, choose the Disk Utility, but don't click continue after the first screen. Instead choose the First Aid tab and click Repair Disk. After the repair has finished, reboot and see if it helped.
May 08, 2009 | Apple MacBook Mac Notebook
My MacBook will not boot up
go to bios setup load optimal defaults.
then save.
Nov 12, 2008 | Apple MacBook Pro Laptop Computer with...
Apple macbook pro
http://forums.macrumors.com/forumdisplay.php?f=129 Look here first as I'd need more info prior to Guestimating the cause.. (Were Swamped).. Any way post back.. Sounds like drive failure to me or similar/OS Issue but could be more. Is the flashing/Change Timed or an Intermittent thing..
Mar 10, 2008 | Apple MacBook Pro PC Notebook
Apple MacBook Mac Notebook Logo
603 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
