Techman asked the question did you take of the tapes.
Failing that did you install the software correctly? You do need to follow the instruction explicitly- like come off line, turn off A/V, dont plug in printer until told. Epson are very fussy. Uninstall all the software and start agian
This is common for epsons. If it has sat more than a month, please, throw it out. If you don't want too, the problem lies in the printhead. I use a small syringe with a small rubber hose fitted over where the needle should go, with near boiling water & ammonia mixed and injected it directly into the little spikes that go inside the cartridges. Do this several times, but I'm not promising this will work 100% epsons are touchy at best
if the removal of tape protector from the cartridge, does not solve problem, return it to point of purchase. its a dud. Not surprising, epson makes a very good printer, its usually the printhead that is dies.
The lack cartridge wont print even though its a new one. I've tried the head cleaning utility two or...
(More)
The lack cartridge wont print even though its a new one. I've tried the head cleaning utility two or three times to no avail. The colur caartridge print is normal.
My Epson is printing pages in code and will not stop and the green light is blinking and the red is...
(More)
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
