Question about LG MZ-42PZ14 42 in. Plasma Television
LG 42 inch plasma model # RU42PZ61
My LG plasma just had the left side of the screen go out.  The picture in now just black with colored vertical lines when it is trying to decode the picture.  I've taken the plasma into a shop and they are quoting $123 for a replacement control board and about $500 in labor.  First off, does this sound like they are diagnosing the problem correctly?  Second, if I can get my hands on this part, how difficult would it be to replace the board myself?
thanks,
Mike Tansill
I've been fixing a DU-42PY10X with the same problem. I checked around online and with a friend in the business and both suggested that it is indeed the "Buffer Logic Right" (for the left side). I took the unit apart very carefully and checked the serial number sticker on the board for a number like 6871QRH043A. 6871QRH043A is the part number I need, but it is probably different for you.
The part looks like this (http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/1036658-lg.htm) and is found buried under several boards as well as under one of the main structural support bars. I had to take out the two system boards and their enclosing box, the power switch board, the two support bars and a giant heat sink spanning from the left to the right side at the bottom. Under there I found both of the vertical buffer logic boards (left and right sides). There are nine ribbons that have a flip-up snap to hold them in place to each logic board. And don't forget the 15 to 20 other cables that needed to be removed to get down there. And watch out for the three high-voltage boards (that have very large electronics and heat sinks) -- They will still hold an electric charge.
So, you could replace the board yourself if you are very organized and cautious. There are a lot of screws and a lot of wires and a lot of stuff to avoid. You may be able to get the part number by calling LG's parts department. I got my part for about $90. If you don't have the affinity to take apart consumer electronics already, then I'd advise having someone more experienced do it. I've taken stuff apart for fun for years, so it takes me about two hours to fix it. The $500 labor is steep, but it is that high because of the high voltage concerns and to pay for any mistakes they make.
If you feel you are a capable tinkerer, I'd order the part through them or through LG's parts department and fix it yourself very very carefully.
Posted on Sep 14, 2008
Hi
my LG 42INCH PLASMA TELEVISION has got three lines running vertical from top to bottom two of which are black and one of which is sort of a coloured spectrum i have phoned around but recieved kind of orkward results if possibe wat do you think is wrong with it and is it possible to get hold of the part?
42 inch LG plasma
Check the COF panels if there are SMD resistors on it,resoldering the resisters could fix the problem.
Aug 05, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Colored Lines
Hi
You have defective vertical output IC. and 1.5ohms resistor. this two parts need to replace a new one.
No other...
Thanks!
Jan 08, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Half my screen works
I had this, and it was just a small connection that was loose.
Dec 22, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Mar 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
Black vertical lines
ey there. have you solved this thing yet? you might want to check out this DIY plasma TV repair blog. there's a video on how to fix this.
Jan 23, 2008 | Samsung PPM42S3 42 in. Plasma Television
LG MZ-42PZ14 42 in. Plasma Television Logo
612 people viewed this question
Henry  Thomas
Henry Thomas
