Question about LG Washing Machines
My husband and I are building a new home with a second floor laundry room. We are very interested in purchasing a LG washer (WM2688HWMA) and dryer (DLEX8377WM), but need strategies to keep the units stable so they do not dance and shake on the floor. What can you suggest for us to do to have a stable, quiet, stay-in-place laundry pair? We are planning to have our builder make a 12 inch platform for the washer and dryer, so we will not be using the LG platforms.
  • 5,911 Answers
If you are talking about a front loader, my experience has been that they do not perform well in a second story laundry room, or in mobile homes. The reason is that laundry rooms in these areas typically have a weaker floor than a ground floor with a foundation under it. With an upstairs laundry room the weaker floor structure tends to flex as the washer starts to spin. This flexing causes the washer to vibrate and bounce. The reason is the weight of the washer and the contrifugal force of the drum as it spins. These washers spin at a rate of 1100 to 1800 rpms depending on the model you have. Newer models may even spin faster. Manufacturers and appliance repair companies were left scratching their heads trying to remedy the situation. New stiffer shock absorbers were manufactured to correct the problem on some model washers and the manufacturer also recommended adding a recommended 3/4 inch plywood base under the appliance and screw it to the existing flooring. This helped firm the foundation and distribute the weight more evenly. In many cases, these suggestions helped. I do not know if newer model front loaders have been modified to resolve this vibration problem, but its something you may want to ask the retailer. Keep another thing in mind, although I do believe there are still honest salesmen out there, many of them work off of a commission. Some will tell you anything to get you to buy from them. As a former appliance repair tech, I can tell you many of us were left trying to explain all these problems to angry customers after they spent a fortune on a new appliance only to realize that it may need additional parts or a room modification in order for them work properly. My best advice to you to is to shop around and read some of the consumer reports reviews about the applaince you intend to buy. Also, since you are building a new home, and are planning on having the laundry room upstairs, make sure the flooring is firm and reinforced. I hope you fin this information helpful.
PS I am not in any way trying to discourage you from purchasing anything. I just want to make you aware of some of the common problems that I have experienced. In addition, the dryers typically were NOT a problem because they did not weigh as much as the washer, and they did not have a high speed spinning drum.
Posted on Sep 12, 2008
    Genius:
  • 1,239 Answers
Hi As a safety device, a dryer usually has a door switch that activates the working .A dryer is simply a large drum into which wet laundry is loaded. A motor with pulleys -- connected by a series of belts -- turns the drum. Air heated by a gas heater or electric heating element is blown through the drum to dry the laundry. The temperature and speed of the drum are controlled by a series of thermostats operated from a timer device on the control panel of the dryer.
The control panels on the latest dishwashers can look intimidating. They're loaded with so many dials, push buttons, and other features that the machine looks too complex to repair. This is actually not the case. With the exception of the control panel, dishwashers haven't changed much in basic design over the last two decades.
Recently moved our laundry room from 1st to 2nd floor, not realizing that front load washers are not good for the 2nd floor...
look the really heavy duty floor pads used in horse stables very dense and thicker than anti vib because even it restacked extra weight wont stop the vibration
Jul 27, 2016 | LG Washing Machines
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
I just bought a Kenmore front load clothes washer and will have it delivered in a week. I did not buy the base that raises the washer to a more comfortable height. I was thinking of building a sturdy...
A friend of mine built an 18 inch high wooden base to raise his wife's washer & dryer because of her bad back, and he had no trouble with it. Speaking as a carpenter, I would make sure that your base is designed strong enough to hold the weight of both machines plus the water that will be in the washer. Use 3/4 inch plywood for the top of the base, with a 2x4 frame underneath. If it will be sitting directly on a cement floor, use treated lumber to avoid wood rot.
Jun 18, 2010 | Washing Machines
JUST GOT A NEW FRONT LOAD DUET WASHER - 3.7 AND IT IS KNOCKING AND MOVING ACROSS THE FLOOR. IS THIS A PROBLEM WITH THE MACHINE OR WHAT?
check to see if the shipping rods have been removed,also if machine is located on upper floor laundry room,the floor may not be sturdy enough to counter act the force generated during spin,this is a common issue in newer homes
Mar 10, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Our Kenmore Elite front loader vibrates when it kicks into the high spin cycle. What should we do about this?
if located in upper floor laundry room,you may need to compensate a weak floor by putting an absorption pad under all four legs of the washer...if the dryer next to the washer vibrates when washer is spinning,the floor is the problem,not the washer
Mar 06, 2010 | Washing Machines
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
Maytag Epic Z
heres a product that might be helpful http://www.apwagner.com/index.php?main_page=product_info&products_id=148095 really had good results with this since inroducd a year ago, $ 30 bucks its worth a shot!!!!
Oct 17, 2008 | Washing Machines
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
BAD INSTALLATION ON LG 4.00 WM2496H*M TROMM WASHER.!!!!!!!!!!!
The storage bottoms are ok in quality, and do give you more space. They are built for just the use of the washer/dryer they are made for, so they will hold up. Best idea, is when you get your base units, tell the store you want a new pan liner installed as well. You may also want to tell the store that the installation personel who set up your new machine broke the last one and you want some sort of credit, free delivery, new pan liner, discount, etc. All stores (Home Depot, Lowes, Sears, Ace) that carry plumbing products, appliances, etc, will carry a heavy duty floor pan for your unit. Good luck and let me know if you need further information. Jim
Nov 04, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
221 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
