Question about Gateway FPD 1750 17" Flat Panel LCD Monitor
I have a growing black horizontal line on my screen.
Hello, Last weekend I noticed a small glitch on my screen. It was a small black horizontal line in the lower right side of the screen. I figured it might have happened from my 18 mo old doing something to the screen. But now it is growing! Over the course of the week it has gotten 3 times as big. It is about an inch and a half in size now. What could be causing this and what can I do to fix it. My computer is out of warranty so I don't have many options there. Thanks, jamkr9
  • Jamie Kirby May 12, 2006
    Well, that is what I figured. Hopefully it won't grow too much bigger than it already has. I guess I will have to start looking for a new monitor. Thanks for your help and your swiftness in getting back to me.
    jamkr9
I've encountered the same thing on my lcd. i'm of the type that can't wait untill the dealer is available to answer my questions, so i opened the machine up to get the answers by myself. It turns out to be moist, instead of a crack, which causes oxidation. This explains also the fact that it grows. It is obvious that this cant be fixed... I'm sorry to confirm that your child probably is the cause, but hey, at least it wasnt done by a cat marking its territory, like it was in my case:)
Posted on Aug 30, 2006
  • pascale oomen Aug 30, 2006
    sorry, i should have posted it as a comment...
    it is my first addition tho:)
    President:
  • 3,130 Answers
Sounds like that there was a small ding or crack in the crystal display and as all glass does when it gets cracked the crack will grow. unfortuatly theres not a thing to do untill it breaks or live with it Sorry about the bad news.
Posted on May 12, 2006
4 Suggested Answers
SOURCE: a thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Posted on May 10, 2007
  • 198 Answers
SOURCE: horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
bammbammfran
  • 159 Answers
SOURCE: horizontal lines on my monitor
Lines on screens are usually caused by damage to the ribbons on the actual screen face itself (something only a few professional lcd repair shops can repair).
Sometimes caused by a bump, other times from over-wetting when cleaning, or dampness/moisture issues
The inverter-power board does Not control picture, It just controls the backlight bulbs and powering the video board.
Picture is powered from the video display board.
Posted on Jul 13, 2008
Horizontal 1 inch bar at top of lcd screen
Hello! It looks like you have a broken screen panel. If you have other glitches over the screen can also be graphic card problems. but the LCD is almost for sure!
Apr 02, 2013 | Computers & Internet
My Sharp LCD tv has lines going from the sides to the middle. They started small and continue to grow...getting longer and wider.
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken Good luck in solving the problem and do take care in handling the set because it contains high voltages.
May 31, 2011 | Televison & Video
BLACK GAP ON RIGHT SIDE OF TV SCREEN
This is a sign of an aging horizontal deflection circuit. Go through your initial setup menu and see if the set gives you the option to adjust 'width.' This may have enough range to stretch the video to the edge but it will also affect the geometry of the displayed video.
As of now, the component most likely growing old is an electrolytic capacitor in the horizontal circuit that has lost value. It is usually a bipolar capacitor in the range of 4.7 - 33 uFd. It will likely continue and become more annoying and if you look closely, you can probably see that the geometry of the picture on that side is not as it should be; it will often appear 'squashed' together.
Allowing it to just grow may result in the failure of the flyback (a high voltage transformer) and/or the main power transistor that drives it.
Sep 22, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Jan 11, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Horizontal red lines
Focus block... Have a qualified tech check it out. The FB packs more than a 20,000 volt punch and could REALLY ruin your day...
Bill
Nov 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Gateway FPD 1750 17" Flat Panel LCD Monitor Logo
1,234 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
