Question about Nakamichi AV-7 Receiver
AV-2 surround receiver. No sound
I haven't used the system for a few months. Now there is no audio when set for CD, Turner or Radio. I only get sound when trying the test pattern. Also is there a directory for Nakamichi service in the NYC area. Thanks
  • jrserin216 Sep 12, 2008
    You know what they say there are no silly questions. You are the best and I have egg on my face. Thanks, thanks, and thanks. One last silly question. Do they still sell the remote for the av-2. Mine is not working and yes I changed the batteries.
  • 4,234 Answers
This may sound silly, but make sure that the tape monitor switch is not turned on. If it is not, let me know and we'll look elsewhere.
Dan
Posted on Sep 12, 2008
How to connect cd player to my Yamaha RX-V733
If the RX-733 is similar to the RX-773 then the Audio 1 and Audio 2 ports are audio inputs on the AV receiver. The AV 5 and AV 6 ports are for composite audio/video connections.
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
Radio and CD-6 player
The humming sound prior to cutting out could indicate a short in the unit itself.....remove unit and have it tested!
Aug 21, 2015 | 2003 Ford F-150
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
Wave radio comes on randomly
Random is truly a difficult problem to solve, if no pattern of failure can be detected. It sounds as though the alarm may be at fault. Is the alarm on and set to radio, CD, or beep? If radio, that could pinpoint the problem. If you have another, mechanical alarm, use it for a couple nights with the Bose Wave alarm off. If the Bose still acts up, then it isn't the alarm. Try unplugging the unit, waiting at least 30 seconds, and plugging it back in, which will cause you to need to reset the alarm. Alternately, remove the Bose cover and blow out dust. I find the Bose susceptible to dust as a cause of malfunction, which may point to the cause being the compact design of the unit. Good luck.
Jul 09, 2013 | Bose Wave Music System CD Shelf System
I have a Rosen Piranah Navigation/CD/DVDEntertainment system. Everything was professionally installed over two months ago. All was working well today until I all of a sudden lost audio/sound. What ha
if its only 2 months old take it back you get a years warenty with audio equipment and fitting dont take no for an answer get them to put it right
Oct 23, 2012 | Cars & Trucks
My Sanyo DP23845 23 In. LCD Television does not have any options under set up beside color-how do I add channels?
HDTV inherently provides a superior sound quality simply because the sound of HDTV is digitally transmitted. The difference in sound between an HDTV television and an analog television is rather noticeable. In fact, it is directly analogous to the difference between the music on CD's compared to the music on audiocassette tapes.
The difference in sound quality provided by HDTV televisions and programming does not end there. Many HDTV programs are also broadcast in Dolby Digital 5.1 surround sound, but in order to take full advantage of this technology, it is necessary to have the right equipment.
Dolby technology has been created by Dolby Laboratories, Inc. This technology is the most renowned provider of digital audio technology. Also, Dolby Laboratories is known for reliable and superior products. For these reasons, Dolby Digital Surround has become the standard for HDTV. Many television manufacturers substitute their own surround sound systems, but they cannot live up to the reputation and performance of Dolby. Therefore, it important to check the specs on an HDTV television before buying in order to ensure that it uses Dolby Digital Surround.
When using Dolby Digital Surround Sound, there are three options for set up. The first option is to buy a television with high quality center channel speakers, woofers, tweeters, and Dolby technology installed in the television. With this option, it is unnecessary to buy addition equipment to take advantage of Dolby Digital Surround Sound.
Another option for taking advantage of the Dolby Digital Surround Sound with an HDTV is to connect an external set of surround speakers to the television. With this option, the surround sound set up includes a front pair of speakers, a surround pair of speakers, a center channel, and a subwoofer. Sometimes, the front speakers are "powered towers." This means these towers include subwoofers.
The placement of these speakers is very important for the quality of the surround sound. The Center Channel Speaker should be centered either above or below the television. The Front Left and Right Speakers should be placed in an arc formation in line with the Center Channel Speaker. The Surround Left and Right Speakers, on the other hand, should be placed to the left and right sides behind the listening position. Many people choose to wall mount these speakers.
The third option for taking advantage of the Dolby Digital Surround System included in an HDTV television is to use an external set of front speakers can be connected to the HDTV television. This configuration is useful if there is not enough room to set up the external surround sound system and the HDTV does not come with Dolby Digital Surround installed. This isn't true surround sound, but it is a viable alternative to those who can't take advantage of the first two formats.
The audio and video outputs of the DVD or VCR can be connected to the AV receiver's video outputs. If a separate DVD and VCR need to be connected, one can be connected to the VCR1 connection and the other can be connected to the VCR2 connection. The AV receiver's VCR video and audio outputs should then be connected to the audio and video inputs of the DVD and/or VCR. In this way, the DVD and/or VCR will be able to record video signals that come through the AV receiver and the VHS tapes and/or DVD's will be able to be viewed on the HDTV.
To take full advantage of the Dolby Digital Surround Sound technology, one of the video outputs of the DVD player and/or VCR needs to be connected to the AV receiver. The digital coaxial audio or digital optical connection must also be connected to the AV receiver.
How do I connect my CD player?
A CD player can be connected to an AV receiver. The CD player's digital audio outputs can be used to connect the CD player to the AV receiver. A CD-Recorder can also be connected the AV receiver by using the Audio Tape Record/Playback input/output loop connections. In this way, the CD-Recorder will be able to function much like a standard audiocassette deck.
What else will I need?
Besides the basic electronic equipment needed to set up Dolby Digital Surround Sound, it is necessary to have connection cables. This includes video, audio, and loudspeaker connection cables. These cables need to be at an appropriate length in order to set the speakers in the proper position for optimal surround sound quality.
Jul 29, 2012 | Sanyo DP23845 23 in. LCD Television
My KD-NX5000 has suddenly stopped playing all audio sources. CD's or DVD's start up and the timer shows that CD is playing but there's just no sound. The sat nav works as it should. Haven't...
Did you ever get this fixed? I'm kind of having the same problem, my radio works but nothing else is. I can hear music on the radio but when I switch to cd or bt (iPhone) ... I hear nothing thought (cd) it recognizes discs and I can see them play but no sound. It played before till one day it stopped. I don't know what changed or was set differently.
Jul 08, 2011 | JVC KD-NX5000 Car Video Player
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Unable to set surround sound to work
The media you are playing must have surround sound recorded or encoded on it in order for surround sound to play or occur. Get a DVD or CD that has surround sound stated on the label - otherwise the system defaults to stereo playback.
Oct 31, 2010 | Nakamichi AV-10 Receiver
Turner only selects odd numbered radio stations
this is the frequency settings that programmed in your audio system, reprogramming will be done your problem, if it cant be programmable install a device on antenna output(frequency modulator changer) you will pick-up all station you want but the problem is... the digital cant be set to appropriate radio station
Jul 22, 2010 | Yamaha RX-V663 Receiver
Nakamichi AV-7 Receiver Logo
259 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
