Question about Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C plane paper fax
I have had trouble with it telling me there is an error 41 what it that supposed to mean and how do i fix it so as i can use the machine?
I too had problems with ERROR 41 ( Printhead) & was told it was a common fault -repaired under warranty,But very common.If u push hard enough u should be able to get it replaced free as it is more than a random fault.I understand in the USA the warranty was doubled due to the bad feed back from all the error 41's !!
Posted on Jan 30, 2007
I've just had the same problems on my 3220c. ME code 41 seems to indicate blocked printheads. Move the ink carriage to it's change ink position using the ink button onr the printer. Remove the print cartridges then on the left and right side of the ink holder is a small loop at the end of a wire. Move that to the side and pull it up. Do the same for the other side. Next pull out the print head that these two wires were holding in place. I've soaked the printhead in isopropyl alcohol which has cleared most of the blocked inkjets - at least enough to use the machine as a fax which is our main usage. I'll leave it soaking overnight as well. I've ordered two new printheads from the US via ebay - very cheap compared to the UK cost. Direct link to the sellers own website is : http://www.inkcessories.com/index.asp?PageAction=VIEWCATS&Category=97
Posted on Jan 18, 2007
    Problem Solver:
  • 20 Answers
Error 41 is the printhead, all inks must be replaced at the same time, OEM only.
Posted on Dec 21, 2006
    President:
  • 3,130 Answers
Unfortanatly error 41 means that the printer head needs to be replaced. Got this from the horses mouth. I called the internnational tele # at 1-800-284-4329 and they told me you would need to take in the machine to have this repaired. You can look in your book for a # to find a servicer or go to http://www.brother.com Good Luck
Posted on May 12, 2006
My printer has an error #41 on the screen what
THE ERROR 41 INDICATES AN INCORRECT VOLTAGE COMMING FROM THE PRINTHEAD, THE PRINTHEAD WILL NEED TO BE REPLACED AND THE HEAD I.D. WILL NEED TO BE RESET, ALSO, BROTHER RECOMENDS THAT YOU CHANGE ALL OF THE INKS TO NEW INKS. THE RESETING OF THE HEAD I.D. CAN ONLY BE PREFORMED BY AN ATHORIZED BROTHER SERVICE CENTER. THIS REPAIR CAN NOT BE PREFORMED BY THE END USER. I HOPE THIS HELPS.
Apr 11, 2010 | Brother MFC 3220C All-In-One InkJet...
Error 41 near empty black and near empty cyan.
first, the error 41 will eventually come back sooner if not later.
error 41 means that your printhead is failing.
the error that its giving you now is that your black and cyan cartridges are empty. there are 4 colors in your prnter.
May 31, 2009 | Brother MFC 3220C All-In-One InkJet...
My fax mfc3220c say message error 41 when I turn it on. It also say unplug and call brothers
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Feb 18, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Error 41 MFC 3220C
WELCOME TO THE ERROR 41 DELIMA. YOU WILL NEED A NEW PRINT HEAD, MAY BE U CAN BUY ONE FROM A BROTHER DDEALER AND INSTALL IT GOOD LUCK
Jan 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Print head for brother mfc-3220c
how do you remove the ink cartridge from mfc-3220c when the lever is stucki
May 18, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C
Error 41 is Print head needs to be replaced, on this model it is not a big job, Heads can be purchased from Brother dealers, ring brother to locate if you wish to repair this machine rather than replace it.
Head sells for about $80 for the part from a brother dealer 1-800-284-4329 and it will need a new set of inks too, not really worth it just replace with new machine with ink and a warranty.
Very common issue, brother extended warranty for this fault for two years but yours would be past it by now, the s/n tells of build date, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06.
I beleive that this is a result a lot of the time by the use of refills and remanufactured ink cartridges being used.
There is heaps of info on net regarding "error 41".
Nov 15, 2007 | Brother MFC 3220C All-In-One InkJet...
Error 41
error 41 means that the printhead is defectiv. It has to be replaced. Sorry, no chance to fix it anymore.
Oct 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Printer problem
It needs a new printhead. I have heard you can find them on ebay. A service center would charge you too much to be feasable. Not because they want to rip you off but because they have to make a profit like any other business.
Sep 01, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C Plain Paper Inkjet Fax Logo
259 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
