Question about Sharp Microwave Ovens
My sharp r520lw microwave stopped working.before it stoped working completely it had a problem with the door switch.if i lifted on the door it would work again.now it doesn't work at all.it won't even let me push the cook button.
  • krussell5 Jan 24, 2009
    Ok it's a door alignment issue. How do I fix it? Is there a really simple solution?
  • Sharp Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switchor mount trouble can be caused by slamming the door or by opening thedoor while it's cooking without hitting the Stop pad first.
There areplastic mounts inside the microwave which hold the door switches andonto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it'sa broken tab on the switch holder, allowing the switch to rotate justout of position. This tab can be hard to see, since it is under thebottom edge of the switch.
One test that sometimes helps is togently lift up (and/or push down) on the door or handle as you try tostart it. If it works or tries to work, then it's a door switch mount ordoor alignment issue.
If you or someone you know decide to lookinto it, we have critical information on safety, disassembly and doorswitches at our site, and our link is at our listing here on FixYa:.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 13, 2008
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
Our sharp r520lw just quit working, timer works, light works, all buttons work, (clear, etc) however turntable doesn't work and no
That would be a bad bottom door switch or its mount.
See the help file on door switches here.
See the service manual here.
Dec 13, 2011 | Sharp R-520LW Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Sharp Carousel will not turn on unless I lift gently on the door.
the door interlock switch needs adjusting or replacement
Mar 26, 2009 | Sharp R-1480 Microwave Oven
Oven makes operating noise when doo is closed without starting
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order Sharp parts is Tritronics. You can call them at 866-779-5835.
Nov 21, 2008 | Sharp R-1480 Microwave Oven
I need the user manual for the Sharp R520LW microwave.
You can download that here free of charge.
You will need the free Acrobat Reader to view or print it.
Oct 07, 2008 | Sharp Microwave Ovens
I have sharp carousel R-520JK microwave, the clock and other functions work, but it does not microwave/heat...
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
You can probably find exploded views by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Sharp Microwave Ovens
Sharp 1611
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
Oct 13, 2007 | Sharp R-1610 Microwave Oven
My microwave has stopped working and switched on suddenly!!
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
156 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
