Question about Mitel Superset 4025 Corded Phone (mitsup4025)
Caller ID on Mitel Superset 4025
How am I about to see who is calling me without picking up the line. I use the headset and everytime I get a call I would like to see who it is, but when I press the line that is ringing it just answers the call.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Try pressing the superkey button and then the button that is ringing
Posted on Jan 11, 2009
Superset 4025 call pick up does not work
Call Pick-Up is a function that has to be programmed on the system controller. First a call pickup group has to be established, then extensions added to the group. Also a call pickup function key-combination needs to be defined in the System Options Assignment form. Contact your service company/PBX system support person for assistance with this. Hope this helps.
Jan 29, 2014 | Mitel Superset 4025 Corded Phone...
Caller id displaying DID's
It sounds coincidental. You should contact your vendor as I think there is something in the programming that's changed. Either in the set's class of service or in the trunks class of service.
Jun 07, 2010 | Mitel Superset 4025 Corded Phone...
How do you set up the caller Id on Mitel Superset 4025
Here is the manual it is all explained in it. Link below. edocs.mitel.com/UG/EN/2ICP_4025_UG_R2_EN.pdf
Mar 10, 2010 | Mitel Superset 4025 Corded Phone...
Changing the name on the mitel superset 4025 I have replaced someone at work and I am trying to change her name and add mine. So mine shows up on the caller id when I call someone within the company. How...
Ms. Blackburn, You will need access to the phone system to accomplish this task; the change needs to be done in the “Telephone Directory form” typically this is done by the system administrator.
Sep 30, 2009 | Mitel Superset 4025 Corded Phone...
Losing my transferee in a phone transfer
make sure u have transfer key or 3 way conf have a key dedicated for this purpoise only
Aug 05, 2009 | Mitel Superset 4025 Corded Phone...
Want to divert calls from a Mitel Superset 4025.
Under the Blue Superkey, you can find a Call Forward prompt, enter the extension that you want to transfer your calls to and enable it.
To shut the call forwarding off, go back into the Blue Superkey and in Call Forwarding,t here is a disable call fording option
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
Want to divert calls from one Mitel Superset 4025 to another.
Under the Blue Superkey, there is an option for Call Forwarding.
Go to the call forwarding and put in the extension that you want to forward to, and then enable it.
To disable the call forwarding, you have to go back into the Blue Superkey and disable the call forwarding from there.
It's either that, or your system programmer may have given you a call forwarding button on the set to enable and disable easier.
Too many rings on 4025 Superset
You will need the Mitel system programmer to change the Class Of Service of your set, this will change the number of rings before it goes to Voicemail.
Unfortunately, unless you know how to get into the system or have an administrator onsite that has rights to the Mitel system, a Mitel Specialist will be required to make this change.
Dec 16, 2008 | Mitel Superset 4025 Corded Phone...
Mitel Superset 4025
Is the Call Forward No Answer turned on? Is the voicemail working on other phones, just not this one? If you can verify this I can probably help you.
Jul 18, 2008 | Mitel Superset 4025 Corded Phone...
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
401 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
