Lenovo  Keyboard Logo
SRINIVAS P Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Function keys directly not working (working only after pressing Fn key button).How to open function keys F1 to F10 directly and calculator is not open. Please help me. Our Keyboard MODEL: LENOVO KU-0989
Jose Cada
Level 3:
  • Lenovo Master 3,530 Answers
  • Posted on Sep 08, 2011
Jose Cada
Lenovo Master
Level 3:
Answers
3530
Questions
Helped
964773
Points
9839
Welcome to Fixya
You need to enable it at the Bios. Reboot the computer and press the button that will lead you to the BIOS menu of the motherboard. Go to System configuration and go to actions keys mode. Press enter then select "ENABLED". Save settings before you exit then test the issue.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3026
Points
SIR ,
MY LAPTOP MODEL 3000G430 KEY BOARD IS TOTALLY NOT WORKING . KINDLY GIVE ME SUGGESTION HOW I MAY REPAIR THIS PROBLEM?
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
1helpful
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
9helpful
4answers
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
1helpful
I have a MSI laptop. My wireless internet disactivate on its own. I do not remember which key I have to press to activated it. Can you help me with this? I think I have to press my Function key with...
try
Fn+F1 -
Fn+F2 -
Fn+F3 -
Fn+F4 -
Fn+F5 -
Fn+F6 -
Fn+F7 -
Fn+F8 -
Fn+F9 -
Fn+F10 -
Fn+F11 -
Fn+F12 -
Fn+Esc -
or
Button symbolized antenna near power.
Thanks
I have a dell inspiron 1564. To use the f1-f12 functions require me to first hit the FN button. How do I reverse this so that i can use f1-f12 by hitting them directly and have the current commands...
You can change it so you don't have to use the FN key by going into the settings while you computer is booting.
Reboot your computer
Keep hitting F2 until a greay and blue settings screen comes up
Choose the Advanced menu
Use your arrow keys to go down and select 'Function Key Behavior'
Hit enter
Select 'Function Key First'
Hit enter
Choose to Save and Exit (usually F10)
Should fix it up.
Shaun Thomson
Billy Goat Karaoke
How use the functions key F1 to F12
Hi
In your samsung laptop you'll be able to see a Fn key on the left to windows key and space bar, press that along with the any keys from F1 to F12 and it will function normally.
eg-- Fn key + F1 key will open up windows help (as it happens in normal systems when we press F1 key)
Daniel Scott
3helpful
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
4helpful
2answers
Where is the wireless switch on a Acer Aspire 5735
Usually, if there is no HARD SWITCH for wifi, there is an equivalent keyboard key combination to turn wifi radio receiver ON. Look at your laptop's Function Keys: F1, F2, ... F12. Among them there is an icon for WIFI, something that looks like an antenna with wave signals. Now press and hold the FN key and press that function key with the wifi icon. Example, if the wifi icon appears at F10, then press FN + F10 to turn your wifi ON or OFF.
8helpful
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
