Question about Creda W120VW Front Load Washer
Washer won't spin
I have a front loading Creda 1200 washing machine which will no longer move into the spin cycle. I have rearranged the weighting of the clothes and have tried several different spin cycles on the dial. Of course when the repair man came last week, it worked perfectly fine without any clothes in the machine. It just clicks through the cycle and then either sits there or eventually turns itself off. Any suggestions? I am located in the US.
Its the pressure water valve or valves
Posted on Apr 30, 2009
Check the impeller in the small motor is ok dont worry about it feeling tight as it is magnetic sometimes just to smell the small motor will confirm that is where the problem is you will find this motor in the bottom right hand corner [ looking from the rear ] the empty pipe runs out of it hope this helps
Posted on Dec 13, 2007
Check the motor brushes mine were worn and caused intermittent spin.
Posted on Apr 12, 2007
  • 641 Answers
Does the machine pumps water out ? Open machine's rear panel and check: - Does the motor spin ? - In case your machine use a belt for drum's movment, check that belt isn't broken or lose. - If your motor doesn't spin at all, check that it receive power. In case it receive power, check for motor's resistace and free movment while turn it by hand. If it dosen't get power its look like a timer problem. Good luck !
Posted on May 12, 2006
    President:
  • 3,130 Answers
Sounds like an intermittant timer, A slipping belt if it uses one or a clutch on the drum. I looked for this make and Model and its not in my data? Sorry I cant assist more.
Banging loudly on spin cycle . machine is leveled and clothes are equally distributed
Machine is level but the load isn't.rearrange the clothes to balance the weight in the machine.
Dec 14, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Creda IWD12 makes noise when spinning but still works ok
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
Dec 02, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda eco washing machine won't spin
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Dec 11, 2007 | Creda W100FW Front Load Washer
Creda excel 1200 front loading washing machine
This will either be a blocked pressure vessel, or the brushes on the Motor. I am not sure where the pressure vessl is on this model But you will find it buy taking the top of and finding a round or oval shaped component with a plastic tube running from it. carefully pull this tube of and blow down it. it should be clear. unplug machine first.
Nov 18, 2007 | Creda W120VW Front Load Washer
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
251 people viewed this question
Top Creda Washing Machines Experts
paul
paul
matt
matt
Evan Benson
Evan Benson
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
