Question about Brother GX-6750 Typewriter
Replaced ribbon and it wont print anything - Brother GX-6750 Typewriter
  • Anonymous Sep 16, 2008
    Having a HARD time replacing the correcting ribbon!
    Scholar:
  • 183 Answers
Check to make sure the ribbon is between the two metal "fingers" and the metal cardholder. Also make sure the printwheel is latched forward by pushing forward on the black lever to the right of the printhammer. Turn the knob on the left side of the ribbon, in the direction of the arrow. It should turn fairly easy, if not, or turning it doesn't advance the ribbon, you may have a defective ribbon. If this doesn't cure the problem, you will need professional repair.
Posted on Oct 28, 2008
Why would the printer not print appears like it has run out of ink(is a thermal)?
That printer will work in both direct thermal (no ribbon) and thermal transfer (ribbon) modes. If you are using media designed for thermal transfer printing and don't have a ribbon it won't print anything.
May 14, 2014 | Zebra GK420 Thermal Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
My IBM Wheelwriter 3 is not working. The machine wont print anything after I replaced the ribbon. The printwheel is currently working but, I think the part that presses down on the paper is broken?
The plastic print solenoid cap is most likely broken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Sep 07, 2010 | Lexmark Wheelwriter 3 Typewriter
My typewriter all of a sudden just stopped typing letters. im not sure if the ink has run out...it wasn't fading or anything before it stopped working mid typing
The ribbon might have fade out, please try and replace the ribbon or check the ribbon selector if is not for stencil cutting. If is in stencil cutting it wont print on the papers as u type. Thanks
Apr 29, 2010 | Brother ML-300 Typewriter
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
RIBBONS TO HI TO PRINT THE LETTERS
Take the ribbon out and make sure that it is in correctly. This may take several times. But we just kept messing with the ribbon and eventually it worked...
Mar 26, 2009 | Brother ML-100 Typewriter
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
Replacement ribbon for a brother fax machine
yes it does mean that. send it into Gateway Time Systems in Pittsburgh...they will replace the ribbon, clean and lube it, and make sure the program is up to date for you. they did a wonderfull job on my company's time clock and they barely charged anything. i found them @ www.shop.gatewaytime.com good luck :), Adam
Jun 20, 2008 | Lathem Time Lathem VIS6002 Ribbon...
Brother GX-6750 Typewriter Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
