Is this a laptop or a desktop?
Can you please provide the model of your wi-fi card if you have any installed or if none you would need to purchase one for your computer so it would be wi-fi capable.
Thanks a lot!
1. Before you conect to the Wi-Fi, make sure that your computer has installed drivers for Wi-Fi. 2. Make sure that Wireless is already open or st-up. 3. Look for the Wi-Fi spot area or zone, if there's no Wi-Fi access on that area you may not connect to Wi-Fi.
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional Turn the laptop over, Front facing you. The Battery Compartment is on the Front Right corner. The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head) See if a Wi-Fi PCI Mini Card is installed.
No? You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery. Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
Well you have formatted the system, so you need to install the Wi-Fi driver in order to access the Wi-Fi.
ou must be having the driver CD, If you dot have just download the wi-fi driver from internet and install it on your Laptop and re-start the laptop and you will be able to access the Wi-Fi again.
Regards,
polysandy
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Ok for starters your Nokia 5310 is not a SMART phone so you will not be able to install WI-FI software! Even if you could your phone would have to have WI-FI components built into the phone for WI-FI to work. If you need WI-FI try looking at some of the Nokia N series phones like N95 etc. Because they use Symbian Software they are capable of running applications that can control WI-FI and GPS etc.
are you that ******* stupid that you think that blackberrys have wifi you ignorant lowlife ***** you cheap ***** blackberrys do not have wi fi you better go to a low quality iphone with that **** you have been dismissed wiht your stale ***
Start - control panel - system - hardware -device manager.
Right click on your " wi-fi", once it is installed and turned on.
Right click again on "update driver"
follow prompts
