Sony STR-DE435 Receiver
Problem for Sony STR-DE435 Receiver
Protector flashing
By novice1 on May 12, 2006
Protector continues to flash, even when all speakers are unplugged. Can you help me resolve? Methods for locating internal "short" or whatever the issue may be? Is there a way to reset the unit? Please advise.
Same Problem
Mar 10, 2009
-   can use bose speakrs-   Guest
Oct 22, 2008
-   I have a onkyo amp tx-ds747 n it keeps on saying protector i have pulled the av cables out n the speekes n its still saying it help me please ?????-   Guest
Sep 06, 2008
-   i have a technics SA-AX6 for many years, and yesterday it started to say overload on the display.i unpluged all the speakers but that did not work.please advise thanks hector -   hchaparro
Apr 29, 2008
-   sony str-d665 I have the problem proteccion may be somebody can help me please.-   mayel
Apr 29, 2008
-   I have the problem when I turn on the proteccion is flashing and doen't work.
the model is str-d665-   mayel
Best Solution
posted on Jun 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with my 2 year old Sony STR-DB780, all of a sudden it showed PROTECT nomatter how many times I turned it on and off.
Checking the speaker cabling for any shortcuts and eventually disconnecting all cables did not solve the problem.
So I opened the case and disconnected the pcb where the speaker outputconnectors are soldered to. This small board also had the speaker on/off relais (light blue). I disconnected the main connector (white) from the main pcb and turned the amplifier on again: problem of 'protect; was solved ....
So I checked for short cuts in the pcb, removed the dust and made sure the wires (red black black white) were not touching eachother; the isolation can be damaged by the internal heat and the wires are routed so that they touch internal components.
After reconnecting the main connector the receiver is working well again. No cost and hopefully useful to others!
Solution #2
posted on Apr 15, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This worked Great. I got this item from work for free thought it was broke. I was about to brake it with a hammer than i thought lets go on the internet and so i did an now it works great.
Thanks
Alot
Solution #3
posted on May 12, 2006
Helpful)
techman
Rank: Guru  Sony Expert
Rating: 86%, 7663 votes
If you know how to trouble shoot solid stste electronics then sure we can assist you in repairing the unit. If you have a meter then your gonna first have to locate the audio output Ic'S get a service manual and with the reciver on, measure the voltage on the output pin of the IC. If there's any dc voltage at all on that pin disconnect it and check the other side output PIN Also find the b+ pin and disconnect that too. On each output device. Plug in the unit and it should come out of protection. If it dosen't then theres another short in the drivers and they only way to find these is to unplug unit and staticly check each transistor on high ohms to find a leakage. If you Understand what I just said check these items and get back to me as i would like to see the schematic to assist you in what to check next. If you dont then its time for the repair shop as we cant teach you how to do these repairs overnight as this is a timely learning processe and need schooling to learn the theroy and the experience for the practibility of repairing electronics. Good luck
Was this helpful?
Yes
No
Solution #4
posted on Apr 12, 2008
Somewhat Helpful)
knightstar7
Rank: Wiz  Sony Expert
Rating: 79%, 188 votes
If unit goes into protect mode and stays, it is not a good sign. Either you have a shorted speaker(s) or wires leading to them.
If you disconnect all speakers and you still get protect light, your problem is most likely shorted output transistors /(ICs) and/or drivers. Problem arises form over driving outputs or not enough ventilation when unit gets hot. Just like your car uses radiator to keep in operating range, receiver has finned heat sink that MUST have good air flow to prevent overheating and burnout. This is especially true with high power (100watt +) 5.1 - 7.1 surround per channel amplifiers. Another rule of thumb, never operate receiver/amps in closed rack with unit on top. It will pick up heat from equipment below it
Was this helpful?
Yes
No
Solution #5
posted on Jan 08, 2008
Not Rated)
lucifer2
Rank: Apprentice
Rating: 100%, 2 votes
This happens to me too... I have a DTR 5.4... Worked well for a couple of years... Now it is shutting off when I have the volume up too high... Although, sometime it just does it at random.... Very annoying...
Was this helpful?
Yes
No
Popular Solutions for Sony STR-DE435 Receiver
Questions and Unsolved Problems for Sony STR-DE435 Receiver
Do you recommend Sony STR-DE435 Receiver?
Answer
Answer
i cannot get any sound when i hook up my ps3 to the rxv365 yamaha
Answer
The issue is on the input board there are 2 ic UPC-2581v 15 pin DILP IC one of mine had high... (More)
Answer
i have a sony str-de435...it well shut off...and come back on...sometime it well shut off for a... (More)
Answer
Wondering if you know how to get it off protected mode
Answer
my reciever was working fine then immediately stopped. Naturally, i opened the top and realized the... (More)
15 Other Users Have The Same Problem - Continued
Comment by heavydtone, posted on Apr 08, 2008
I have the same problem,when I turn on the receiver after about 5 seconds the proctector light flashes. I also had 4 ohm speakers hooked up to my sony str-de835 for about 2 days and then I turned it on and it when into protect mode. Is there some kind of reset you can do to fix this problem?
Comment by EREHDER, posted on Mar 08, 2008
I HAVE A SONY STRD665 RECIEVER THAT IS IN PROTECT MODE. DISCONECTED ALL SPEAKERS AND TURNED DOWN ALL VOLUME.
CAN I RESET THIS
EREHDER62@AOL.COM
Comment by digipro, posted on Mar 03, 2008
Hi. I have the same problem with the PROTECT message on my TX-SV636 tuner. I found that I had 4ohm Bose speakers hooked up to where it says they should be 8ohm on the back of the receiver. They work fine for about a month, then one day PROTECT appeared... Obviously my fault but do I need a tech to fix it? Or can the problem be pinpointed because of my specific error?
Thanks
Comment by Guest, posted on Jan 08, 2008
protector flash across screen,nothing works
Comment by Grizzely, posted on Jan 01, 2008
I pulled the whole system and have removed the tuner.
Comment by jttucker, posted on Dec 23, 2007
turn power on wait a few secs and protector flashes continously no sound and no controls
Comment by Guest, posted on Dec 10, 2007
unpluged power and speakers
Comment by 21blind21, posted on Nov 21, 2007
my protecter keeps flashing when the speakers work and its all good
Comment by David CRASH, posted on Nov 21, 2007
When I turn my volume up the stupid protect flashes on the display and then the unit turns off. The receiver worked great for about a year with no problems. Now all of a sudden I am having problems and I have not changed any equipment or settings. Please Help.
Comment by stock, posted on Nov 17, 2007
Power on...within a few minutes Protecter flashes
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receiver Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
