Question about Black & Decker String Trimmer Cordless 12" 18V
Battery replacement for unit
Where do I find a replacement battery for my trimmer?
It is a 12vdc and I can not find one anywhere.
Thanks
Tom W
The unit itself is obsolete.
However....
Open the unit up (six cross-head screws). Inside you'll find a 12V 5.0AH rechargeable battery, like the kind used in many home alarm systems.
You can get a replacement at most battery stores (they'll even pre-charge it for you). Somewhere around $20, I guess.
Posted on May 28, 2009
On the Box for mine "Black and Decker Grass Hog 12" Auto Feed Trimmer/Edger" it has an area that says the following;
Replacement Battery Part #243215
Call 800-258-6003
Goodluck
Mike W.
Posted on Sep 14, 2008
I have a Florabest cordless grass trimmer, ref FRT 18 A1, which I purchased in England over a year ago. It works well, but I think the battery needs replacing. I can't find a supplier anywhere. The...
You could try searching for strictly a battery supplier who might be able to cross-reference your battery to something equivalent.
Nov 04, 2013 | Garden
How to take razer apart to replace batteries.
My thanks to everyone who viewed my question. I feel so embarrassed now since I lo0cated the answer accidentally on my own. Here is the answer: When I opened the "trimmer" on the razor itself, lo and behold the answer was already there. It gave the exact answers I had been seeking. It said "For the HGX-1, it requires a PA-650 which delivers 12vdc @ 650mA. I found a compatible charging power transformer which delivers 12vdc @ 500mA and it worked fine in recharging my shaver. So, thanks to each of you for trying to locate the answer for me.
Jun 18, 2011 | Remington HGX-1 Electric Shaver
Conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Nov 11, 2009 | Conair Deluxe Rechargeable Beard &...
Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Jun 25, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Trimmer Question
mains, battery or petrol A hedge trimmer can be powered in 3 ways: mains electricity, rechargeable battery or petrol. They all have their advantages and disadvantages, so decide which is best for you. Electrical hedge trimmers provide a clean lighter weight option with the convenience of immediate and continual use. However you may be restricted by cord length - not ideal if the hedge is a long way from your power source and having a cord can be obtrusive and dangerous. Rechargeable hedge trimmers give you the best of both worlds. They're clean to use and have no cord so they can be used anywhere, without the danger of accidentally cutting the cord. They are less powerful than petrol models and you do need to plan ahead though and make sure your batteries have been charged. 5-7 hours of charging will give you just 30 minutes use. A second battery will give you back up but if you're cutting for long periods of time, you may find this timescale too restrictive. Petrol hedge trimmers can again be used anywhere, there's no cord so they're safer. Just top them up with petrol and away you go, no charging necessary. These models do tend to be harder to use - they're heavier, noisier and smoky.
Aug 27, 2008 | Electrolux Gas Hedge Trimmer
Power is out
Tom, usually those can be replaced by the End User. It's rare that they'd be sealed inside, but that does happen at times. The big issue is finding replacement batteries of same type/size fit, and you'd need to do that online.
Feb 03, 2008 | CyberPower 725SL UPS System
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Black & Decker String Trimmer Cordless 12" 18V Logo
933 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
