Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Help in Houston
We have a kenmore Side by Side that we want to run from a 750 watt power converter connected to our car battery. Possible?? Safe???
  • 828 Answers
750 watts is low output for a side by side. 750 watts is not sufficient to provide starting power draw for the compressor start-up. The first three seconds or so require a surge of about five times that ratting.
Posted on Sep 14, 2008
Wheel Horse 111-B&S 11hp eng-where do i conect red & black wires from charging system
Your Briggs & Stratton uses a dual circuit type alternator. One side of the unit produces up to 3 amps of DC electricity via a one way diode so that only the positive charged electrons pass through converting the AC from the alternator into DC after passing through the diode. This wire will have a slight lump just before the wire terminates at the plug. This is the wire that will be red and it needs to be connected either to the battery side of the solenoid or directly to the positive terminal of the battery. This keeps the battery charged an also provides enough power at full speed to run the electric clutch.
The other wire does not pass through a diode and therefore produces AC current for the lighting system only. This will be the black wire after the connector. The black wire connects directly to the headlight switch. The AC side produces 5 amps at full speed and therefore enough to power 60 watts of lighting at 12 volts. The typical 1156 bulb uses 28 watts x 2 = 56 watts and if the unit has taillights they are normally 3 watt bulbs. The headlights will be dim at low speed and reach full brightness at full speed.
In Summary, red wire to battery and black wire to light switch.
Hope this helps.
Apr 07, 2014 | Garden
I have a kenmore refrig/freezer. Full load amp is 6.5 , 60 hz and 115 volts. I have a generator that will take 1100 watts with 1500 peak or surge watts. I heard that refrigerators use more electricity or...
The calulation of max wattage is going to be 750 watts at start up and be around 500 on normal running wattage after start up so a 1100 watt generator should be fine.
GENE
Sep 06, 2011 | Kenmore Refrigerators
How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
When i hook up my 750 watt inverter to my truck do i need to install a isolator or inline fuse? or just connect the 4 gauge battery cables directly to the battery and the inverter?
Yes, inline fuse as close to the battery as possible. If 4 gauge wire were to ground out without fuse, would most likely start a fire or at least damage other existing harnesses (depending on routing) before a person could disconnect battery.
Oct 13, 2009 | Whistler PI-1200W 1200-Watt Power Inverter...
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
Aug 02, 2009 | PPI DCX-1500.1 Car Audio Amplifier
If a use a voltage converter 120 watts to 220 watts,
yes , just use a voltage step down transformer ( voltage converter) 200W
Jun 15, 2009 | Kenmore KSM100 Stand Mixer
Connection to car battery
The answer is yes...BUT make sure the polarity is correct and the inverter turned off when you make the connection
Apr 30, 2009 | Black & Decker 750w Power Inverter
Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
DISCONNECT YOUR BATTERY!!
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
124 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
