Question about Zenith B32A34Z 32" TV
Tv won't get channels
My zenith b32a34z isn't really getting any channels anymore. i was getting cable before, but something happened (i don't know what) and now it's only finding about 2 channels that would be on normal antenna mode, but none from cable. i've gone through every option and i can't find a way to make it see that it's connected to cable. i've tried the ez program mode and the cables are inserted securely. according to my boyfriend, there used to be another option in the menu to switch from antenna to cable. but now when i go to source, the only options are "antenna/cable" and "video". any help would be greatly appreciated.
    President:
  • 3,130 Answers
We have the owners manual in case you misplaced yours . All ya gotta doi to get it is to click on the zenith B32A34Z model # At the top of this page and scroll down to the manual. Now according to the manual in the menu there is an antenns /cable setting and its in the EZ progrom mode. look at the manual as I dont remeber 100% but its there. It sounds like you or someone switched it when they were in the menu. Good Luck
Posted on May 12, 2006
My tv's freeview wont let me view any other channels apart from the bbc
Freeview? I'm not good with tv words... Is freeview a free channel you stole from the neighbors dish (don't be ashamed)? If so, then you should buy cable (Cable's better. Really. Satellite dish companies looked one thing over. Storms ruin your tv.). If your just watching what you can get through the air, well, that won't work. After a while, you start to lose channels. Just get cable. If you already have a tv network, then you should call the tv company.
Jun 18, 2012 | DMTech DM-AV10 Digital Media Player
Zenith PV4663RK Rear Projection TV - Manufactured - Mar. 1995
Are you connected to cable TV using a digital receiver? If so, your TV can only get the signal for one channel - the one you're tuned into on your receiver. A workaround is to connect the coax cable TV cable directly to your TV, as well as connecting your receiver to your TV. This will allow you to be able to change the channel on your receiver and be able to change the channel on your TV to one of the analog channels you can tune into by connecting the coax cable directly to the TV.
Jan 09, 2008 | Zenith IQB50M90W 50" Rear Projection...
Tv makes a beeping noise and i smell electronics burning
Time to upgrade as the cost involved is not worth it.
Dec 05, 2009 | Zenith B32A34Z 32" TV
I have a Zenith B25A242 TV. Can't get cable channels
Select cable, then with your remote, go to menu and perform channel scan.
Oct 31, 2009 | Televison & Video
Sound
I do not have a Zenith B25A02Z TV. What I do have is a 1988 Zenith Color TV SE2517P. I called a local tv repairman and discussed the problem over the phone. He can take a look at it if we bring it in (service call to the home cost $100 just to show up). He said it was worth fixing since he thought it was only the sound. We have a great picture. He charges $20 to look at it but we have to leave it. He lives 20 minutes away one way. We think it is worth the trip if we can get it loaded into our minivan. We live in western NY where the weather can get pretty ugly many days. I will post the solution later when I know. FYI
Dec 30, 2008 | Zenith B25A02Z TV
Tv remote control does not work with tv
some zenith ha tiney slide sw on back apron. in linecord area.
Dec 02, 2008 | Zenith B32A34Z 32" TV
Menu keys not working & Chanel 2 & 3 Only
Greetings Eagle7eye,
It sounds like you might have a problem with the cable settings for your TV. There are a few standards for cable broadcasts and you may need to set it to standard or "STD". But since your menu button doesn't seem to be working this would pose a problem.
I would try and access your settings with the universal remote and look for something like antenna (ANT) and change it from air to cable. Depending on how old your TV is too there may be a small switch near your coaxial connection for the cable setting.
Good Hunting.
Jon
Go Ahead. Use Us.
May 05, 2008 | Zenith B32A24Z 32" TV
ZENITH
Your tv does not need an internal cleaning for brightness, I suspect that your tube has aged and either needs an adjustment or replacement.
Jan 29, 2007 | Zenith B32A34Z 32" TV
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
Power on off switch not working
Do not operate the set anymore, before taking the following steps, or damage to the HOT, electrolytics or zener diodes may occur. - see if there are 2 small electrolytic capacitors in the primary part of the power supply, could be C909, C910, C911 or something. The values are usually 47u 25V and 10u 50V. Especially the 47u which is in the base drive of the switching transistor causes over-voltage conditions. They both should be replaced. - there should be a 2SC2335, BUV46, BUT56 or BUT11A in the +105V line on the secundary side of the power supply. This is probably shorted thus causing no power-off. Replace it along with the transistor driving it (2SA1013 probably). If the above does not apply to your TV, you're on your own for now, and you may actually be having a microcontroller faillure...
Oct 06, 2005 | Zenith B32A34Z 32" TV
Zenith B32A34Z 32" TV Logo
95 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
