Question about Zonet MULTI FUNCTN USB 2.0 PRNT SRVR (ZPS2000) Print Server
Zonet 2000 Does this print server work with windows vista (64bit) when I installed it -driver failed-should I return it?
  • place4spam May 22, 2009
    I have a similar problem. ZPS2000 and drivers work OK with other XP PCs in the house, but installation of drivers on Vista laptop fails when using supposedly Vista compatible install off Zonet web site. No explanation except driver install failed. No mention in Zonet support. Bummer on an otherwise fine, good value product.
5 Suggested Answers
SOURCE: Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Posted on Mar 01, 2008
SOURCE: D-Link 301U Printer Server using Windows Vista
Here it is listed as compatible: http://www.dlink.com/products/vista-support/
The above says no Quick Installation Guide only.
Posted on Oct 09, 2008
drifterK
  • 4924 Answers
SOURCE: i purchased an epson stylus photo 1400 printer for
http://www.pcguidebook.com/downloads/printserver.pdf
Here you have instructions about how to set a print server in the router ..and all conflicts that may appear ..Please read carefully cause some of teh steps are needed just in conflict conditions ...and you do not have to run them all ..
The actually first step is to access the server by its IP address and make teh settings for the printer ...after that you should install the printer driver in the computer ..and take the printer and faxes wizard to make the default printer settings ..(choose it from the list after it is correctly connected to the prin server and this one connected to the router )
To connect it to the router you should get into its setting and basically its the same as connecting a computer ..
Posted on Dec 30, 2010
muntejaya
  • 10421 Answers
SOURCE: Installed 3 Zonet Parallel print
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__m9jch56
Posted on Feb 26, 2011
Emachines G640G 6670M
Open Device Manager, Uninstall the Graphic Card and driver, reboot the machine, allow Windows 7 to apply the generic driver, Open Windows Updates and run. OR, open Device Manager, display adapter, update Graphics adapter. OR, Use the eMachine windows vista 64 bit drivers. Download the Windows Vista 64bit driver and Save , open Properties, change compatibility to Windows 7. Take a look at this : http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/
Feb 06, 2013 | Computers & Internet
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
I cannot find a driver or SW package for Windows 7.
Tripplite bought Keyspan and are no longer supporting it. there are no 64bit drivers.
May 15, 2010 | Keyspan USB Server US-4A (d47710) Print...
LBP2900B DRIVER CD
CANON LBP2900B DriversHere is the driver for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7
Installation Procedure when Connecting USB Cable
Do not connect the USB cable until after you have loaded the downloaded files.
After all files have been loaded connect the USB cable to the back of the printer.
DRIVERS
Thanks & Regards
M. Nanda Kishore
Dec 29, 2009 | Canon LASER SHOT LBP-2900 Printer
Where can I download the driver for Fuji Xerox DocuPrint C1110B color laser printer?
You can download a latest driver for Fuji Xerox Docuprint c1110b Color Laser Printer in this URL
http://www.fujixeroxprinters.com.au/en/support/Downloads.aspx?product=8645&category=5726&os=8388608
Driver Version: 2.6.15
Driver Languages : English, Chinese - Simplified, Chinese - Traditional and Korean.
Operating System
Microsoft Windows XP Microsoft Windows 2000 Microsoft Windows 2003 Microsoft Windows 2003 64bit Microsoft Windows Vista 32bit Microsoft Windows Vista 64bit Microsoft Windows XP 64bit Microsoft Windows 2008 64bit Microsoft Windows 7 Microsoft Windows Server 2008 Microsoft Windows 7 64bit
Printer Language: PCL
WHQL: Yes
Dec 04, 2009 | Fuji DocuPrint C1110B Laser Printer
I need driver of us robotics fax modem model 5633
For Windows 2000, Windows XP, Windows Server 2003, and Vista 32 bit Click HERE.
For Windows XP 64bit Edition (Rare), Windows Vista 64bit Edition (Not Rare) and Windows Server 2003 Click HERE
For a link to the Download page click HERE
Hope this helps.
Brad Wieland
Nov 13, 2009 | HP Computers & Internet
Have a ps 110 netgear printer server Vista will not requnize it
I have no problem using Vista Home Preimum notebook that print to the NetGear PS110, and now the notebook upgrade to Windows 7 Preimum, it still works. All other computers using XP, Win 2000, all work fine with PS110. Basically, install the printer drivers to LPT1 first, then add a new local port with \\PSNNNNNN\P1, then it just work. no problem. (note that, you have to configure the PS110 using same subset ip address first.)
Mar 17, 2009 | NetGear PS110 Print Server
Can't connect my Linksys WRT54GS router to zonet zps1000
The gateway would be the address that your router uses.
You would plug the print server into the back of the computer using the ethernet line.
Use this link to get into the support section of the website:
http://www.zonetusa.com/index.asp
Dec 30, 2008 | Zonet (ZPS1000) Print Server
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Zonet MULTI FUNCTN USB 2.0 PRNT SRVR (ZPS2000) Print Server Logo
97 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
