Question about Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive
Acomdata external harddrive is not recognize on vista
My external harddrive was recognize on windows xp and when I installed vista ultimate it does not recognize my external drive?
  • 1 more comment
  • Anonymous Feb 24, 2009
    it shows the drive under diskmanament and it shows the partitions. but it shows them as being blank and i know there not. it seems to me to be a registry problem with vista. i use a lot of differant ext hard drives. its like it ran out of drive letters or some thing. thanks ms
  • dumbitall Mar 12, 2009
    I purchased the Acomdata external combo hard drive with pushbutton manager and just loaded Vista today and now find that it works only with XP or earlier. Acomdata has moved and has new phone numbers. I sent a tech request but have not heard back yet.
  • Anonymous May 11, 2009
    vista sucks
  • 3 Answers
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Posted on Apr 21, 2009
Acomdata external hard drive not opening MBP
Acomdata Drive Not Recognized: I ran into the same issue. Actually the issue was with using an incorrect power adapter. It should be with power ratings of: Input 50-60 Hz 1.2A & Output 5V - 2A, 12V - 1.2A
Jun 22, 2012 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
My bio500ue enigma 500g acomdata hardrive, works just fine on my computer with windows vista, but my new computer with windows 7 doesn't recognize it and gives me messages saying it hasn't installed...
your windows 7 is trying to use the native driver for usb hard drive, but its having a hard time installing it so thats why you are getting it hasnt installed properly, you may want to install a driver specifically from your HDD manufacturer try to look for the driver on the website. you can also use the driver for vista on 7. hope that helps
Mar 23, 2011 | Acomdata BIO500UE Enigma Ruggedized with...
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
My mac is not recognized my external drive
My computer with Windows XP is not recognized my Acomdata extenal hard drive
Nov 15, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
Taking windows vista off my sony vaio
do you have both original OS?
if your laptop had XP on factory defaults you migth whanna look for recovery disks. if a friend full formated your harddrive when installing vista, then get a copy of windows XP and put the key of your laptop.
hope it helps
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
External USB drive making clicking noise - Windows does not recognize it!
The drive is damadged bad. youll have to go to a data recovery centre, but that can cost $700+ if you really want your data back.
Sep 19, 2008 | Western Digital (WD1000VE) 100 GB Hard...
External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Mar 13, 2008 | Acomdata HybridDrive E5 Hard Drive
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive Logo
1,271 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
