Question about Aiwa NSX-TR77 CD Shelf System
Aiwa NSX-TR77 I Tested out the speakers with some BASS MP3s to test the bass and the Hifi Went off, it shows only the red standby light. When i click power on it says HELLO then it goes off to standby :( MSN is jamez666@hotmail.com Email Jamez666@goowy.com any help would be greatly appreciated :(
  • james jay May 12, 2006
    The speakers in the Hifi was not the original ones, but they wasnt over 300W they was ok for months until i tested it on full volume :(
    It doesnt even come on without speakers or diffrent ones so its def not the speakers, something inside it must of gone i dont know about HIFIs. It sounds to me like it needs a new power supply unit inside it, im an IT Tech so i wouldnt know.
    Im a bit stuck as in what i should do now ? Is it worth taking to a repair shop ? it was £199 when i got it.
    I also had a sharp 5 speaker hifi and it started smokking when i connected about 10 speakers into the back and i dont know if i should throw them away.......
    Thanx for your reply i didnt think i would get a reply.
    President:
  • 3,130 Answers
Well Jamez sounds like you have eather blown the soeakers or the output IC's inside the unit. If you have a meter you can simply disconnect the speakers and test the resistance of the speakers with an ohm meter. If you dont have an ohm meter then you can connect them up to another stereo or have them and the unit tested at a repair center. Sorry not really any serviceable parts in these systems. Good Luck
Posted on May 12, 2006
  • Larry  Dillon
    Larry Dillon May 12, 2006
    Jamez!!! of course your gonna get a reply if we see your post@!! Now with your problem its a possibility that your power supply is blown BUT I bet my last dollar that you blew up the out put ICs as you cant overdrive these systems like the old to3 output transistors or even the old tube amps By connecting 10 speakers to them!!! Im not sure what Pounds convert to in american mony but Its probably fried beyond repair. In the future if you need more power or more sound hook up an addition amp to your uunit through the audio output low impedence plugs and drive the sPeakers with another amp. As you shouldnt ever go below 6 ohms on most of thes shelf type systems. maybe 4 ohms tops. If you add two speakers together that say are 8 ohms it cuts the impedence in half to 4 ohms so that would be over driving the system by double of what you should be driving it at Thats why at high voluyme you smoked it. Good Luck Man
Stand by problem
do have the the circuit book of aiwa nsx k880
Apr 08, 2014 | Aiwa Audio Players & Recorders
Light turns on but no sound
This is a powered sub, which means it has it's own amplifier providing the power for big bass. When you removed the back you probably removed it's amplifier too so it's normal that now you only get the bass performance of a normal speaker.
Oct 17, 2012 | Aiwa TS-W60 Subwoofer
I want to play my music from my itouch on my Aiwa NSX-TR77 system (because of the speakers) but do not know how to, or if this is even possible to do so?
It is in fact possible... you can play whatever source to whatever sound system with the correct cable... you need a cable with at one end a headphone output connector (compatible with your Itouch) to an input of your choice on the Aiwa system... usually RCA input (RED & WHITE RCA type connectors) at the other end of the cable...
Cheers!
Aug 31, 2011 | Audio Players & Recorders
Not getting high depth of bass sony MHC-RV777d
I wouldn't expect huge bass from those little speakers. Somewhere on there, there's an equiliser, where you 'll probably be able to turn the bass up and down. See if that works. If not, new speakers may help.
Jan 08, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Logitech z5500 power problem
I replaced the fuse in the subwoofer. Solved the problem, without a hitch. Just take the current one out and bring it to an audio/hifi shop. Ask to buy a similar one.
PS. The fuse might look damaged, but then again, it might not. Have the audio/hifi guy test the current fuse, that way you know if that's the problem.
Oct 31, 2008 | Logitech Z-5500 Computer Speakers
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
Aiwa NSX-TR77 CD Shelf System Logo
479 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
