iiyama ProLite E430T 17 in. Analog TV LCD Television
Problem for iiyama ProLite E430T 17 in. Analog TV LCD Television
Bush 17" LCD TV
By conie on May 11, 2006
can anyone help? I have a bush 17" widescreen LCD and typically has just ran out of warranty, the picture has dissapeared but he sound still works....I put the teletext on then tried to return to TV but got a black screen instead. Dont know how to fix it or can someone give me some info as to get it repaired.
Many Thanks
Same Problem
Feb 26, 2008
-   hi we have a 26 inch bush lcd the picture has developed a patchy bright blue background there are parts of the picture that is fine but the rest is bright blue this happens and after a while it may go back to be perfect then go funny again has any one got any ideas many thanks paul-   paulmac40
Best Solution
posted on May 11, 2006
Helpful)
techman
Rank: Guru
Rating: 86%, 7635 votes
with your remote go into the menu and do you see that??? ok if you do go to the closed caption and see if its off. if its not then you have a backlight problem and you should seek professonal help with that. Good luck
Was this helpful?
Yes
No
Popular Solutions for iiyama ProLite E430T 17 in.
Questions and Unsolved Problems for iiyama ProLite E430T 17 in.
Do you recommend iiyama ProLite E430T 17 in. Analog TV LCD Television?
Answer
Answer
How do I find the Set-Up Code for my 26HF5544D/27B Phillips Tv/Monitor ? I am unable to get into the... (More)
Answer
lvm-37w3 whitewestinhouse LCD TV is multisystem (PAL-N / NTSC)?
Answer
Thick black line in the middle of the screen
Answer
sound not working on toshiba model number 32hl67. I tried unplugging it, audio settings, unplugging... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For iiyama ProLite E430T 17 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
