Question about Palm Treo 650 Handheld
My Treo hangs frequently
I have a Treo 650 which hangs frequently, which can only be solved by resetting the device. Any idea?
  • ashishleepa Jan 08, 2008
    i have a treo 650 which hangs very often, sometimes just after making or receiving a call. If I switch the phone off, the other functions and applications work absolutely fine.
    i have done soft & hard resets succefully but have not been able to do a zero reset.
    pls advice, and kis there a centre in new delhi india where i can get it repaired?
  • 38 Answers
It's mainly due to NVFS and its variable database positions as well as DBCache running out of Cache space. I use a combination of RescoLocker to "lock" the apps so that it won't cause a reset (esp with older apps), Pref Doctor, and Resco Backup a reliable backup program.
Posted on May 15, 2006
  • 64 Answers
What apps do you have installed ? Are you sure they are all compatible with Treo650 ?
Posted on May 14, 2006
650 manual
Here are a couple links that should help you.
One link is the manual for your phone and the other shows you how to reset your phone which should solve your issues.
Hope this helps.
http://support.sprint.com/global/pdf/user_guides/palm/treo_650/treo_650_by_palm_ug.pdf
How to Hard Reset Treo 650 eHow
May 14, 2014 | Palm Computers & Internet
Language settings
Bueno, trata lo siguente:
If you purchased the Treo in the U.S., you should have the English to Spanish option when you reset the phone. Just make sure to back up your data before resetting it.
HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
Step2Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset. Step 11Let go of the red phone button when you see the Palm screen. Step 2Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset. Step 3Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone. Step 4HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Do not forget to back up your data before performing the hard reset. If you don't, only the data from your last HotSync will be able to be recovered.
  • After performing a hard reset, install your applications one at a time to make sure each is in working order. Delete any applications that are not in working order, as those might have caused the need for the hard reset in the first place.
Buenas Suerte,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Joe Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 22, 2009 | Palm Treo 650 Handheld
I forgot my code to unlock my palm treo 650 cell phone
A last resort is to hard reset the device, but you will loose your data.
See here how to hard reset.
Jan 09, 2009 | Palm Treo 650 Handheld
How do you do a hard reset on a treo 650
1. Backup your data first.
2. While holding the red hang-up key, click the reset button. Keep holding the red key until after the progress bar completes and the Palm logo shows.
3. You are then asked if you are really sure - Pressing the up key at this point completes the hard reset.
Dec 18, 2008 | Palm Treo 650 Handheld
Frequent hanging of my new palm treo650
If it's new, it's under warranty, get a new one.
Also, if you have tons of add-ons, this can cause frequent hangs. Uninstall some of them.
May 25, 2008 | Palm Treo 650 Handheld
Call forwarding with Treo 650
Call forwarding is not controlled by the device itself, but the switch which is serving your cell phone. Most carriers have a start code to change the number of rings before forwarding usually *74 send then press the number of second before forwarding each ring is about 3-5 seconds or something to that effect. If you contact your carrier they should be able to tell you.
Jan 08, 2008 | Palm Treo 650 Handheld
Treo 650 keeps shutting itself down
Hi muchlove,
Please backup your palm to memory card using palm backup application or hotsync it to your computer, then you do a zero-reset. Here's the step by step how to zero-reset:
http://tinyurl.com/babb7
If this solve the problem than it caused by software conflict. Please let me know the result.
Nov 02, 2007 | Palm Treo 650 Handheld
Treo 650 - Changed system name
The answer is HARD RESET your treo.
Sep 12, 2005 | Palm Treo 650 Handheld
When I hot Sync my Treo 650, my tasks hot sync fails
I changed so that the desktop over-rides the handheld and the hot sync went through. This is not the way I perfer this, but it worked. I have not switched it back to sync the files yet to see what would happen.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
152 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
