Question about Hoover Washing Machines
We have no power and the fuse is fine any ideas?
Posted on Mar 19, 2011
Hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Posted on Sep 12, 2008
Jul 19, 2016 | Hoover Washing Machines
Mar 02, 2015 | Hoover Washing Machines
Mar 22, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Sep 21, 2013 | Hoover Washing Machines
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
Feb 14, 2011 | Hoover Nextra HNF 3157 Front Load Washer
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Feb 01, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Jul 03, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
297 people viewed this question
