Question about Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset
Plantronics voyager 500a
We moved these units from phone to phone. I have it plugged into the new phone and if you are looking at the unit, the red light on the left just blinks and the blue light that is on top is not on at all. I let them charge all day yesterday and today thinking it might be the battery. Can someone please help? I have two of these and they are doing the same thing.
  • 16 Answers
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Posted on Oct 03, 2008
  • daveyedison1 Jul 26, 2011
    Wow, that worked perfectly. Thank you so much Peter.
Thank you I tried that for my problem and it worked. You saved me having to purchase another base and that is alot 250.00. Thanks again!
Doreen
Posted on Oct 25, 2008
Thank you!!! You saved me from another day of a neck ache!!!
Posted on Jun 23, 2010
That solution has worked in the past so thank you! Unfortunately, I am trying to connect another one and it's not working. The flashing red light will speed up, be steady for a second, but then resume flashing normally. Also, when I put the headset into the base, it flashes red. Any suggestions?
Posted on Dec 22, 2009
2 Suggested Answers
SOURCE: Plantronics voyager 500a
Turn on the power on the headset. It's the button on by the volume.
Posted on Mar 27, 2009
I can't get the blue light to come on top of the base. The red lught keeps flashing and the amber light is lit. Plantronics 500a headset
The Plantronics 500A is the base for the 510S system, the headset may need to be re-paired to the base unit to make sure that it has a strong link or connection. Here are the links below for the pairing instructions, and also the user guide.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
http://www.headsetsdirect.com/pdf/510_print_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Aug 23, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Phone lifter not working. light on top of base not lit up
Try re-pairing the headset to the Plantronics 500A base unit, it sounds like the headset may have lost connection with the base. Here is the link for the pairing instructions:
Plantronics 500A Pairing Instructions
Good luck from Headsets Direct!
Jul 06, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Headset not working. red light on base is flashing and yellow light is static; no blue light
It sounds like the headset may have lost connection with the base, try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Feb 09, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have half a dozen plantronics voyager 500a units, with HL10 headset lifters and 510 bluetooth headsets that do not work. All of these came from the Voyager 510s packs some time ago (with a different...
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
I was searching for this today and happened to find the above on the plantronics website. It definitely frustrated me till I found out about how to put the base in pairing mode.
Jan 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I've plugged everything in, no signal on headset...what could be the problem?
Make sure that the Plantronics Voyager 510S / 500A headset is powered on (remember that it has an individual power button on the actual headset), and that it is paired up to the 500A base unit. Below is a link for the user guide.
Plantronics Voyager 510S/500A User's Guide
Oct 27, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics Voyager 500a Bluetooth Headset
Try re-syncing the headset to the base unit:
Jun 22, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Sep 12, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset Logo
5,825 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
