Question about Kenmore 24032\24036 Top Load Washer
Small amount of water from washer
My Kenmore older model washing machine has started leaking from somewhere, just a small amount of water, a cup or less, appears on the floor in front of the washer AFTER the cycle has finished and the washer has sat for a few minutes. Not the hoses. Any ideas?
    Genius:
  • 1,028 Answers
Ck around pump at place motor shaft connects ..that is mot likely place
Posted on Sep 13, 2008
What causes a bad smell to come from a washing machine
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Dec 12, 2010 | Washing Machines
My kenmore washer has just started this week leaking water underneath somewhere!! I noticed water down the side next to the wall & behind the washer. I then placed a few small towels behind & down...
This is either your water pump, inlet valve, or you have a hole at the top of the outer drum. Try using the small load water level, if no leaks try medium. Also try seeing if the hoses are leaking. I also have seen mice bite holes in the drain lines. I hope i have helped you. God bless!
Aug 20, 2010 | Kenmore 26442 Top Load Washer
My Kenmore front load He2 fills with water in the dispenser cup then spills out from the dispenser cup onto the floor. Can anyone help?
SOLUTION...DON'T BUY THIS PRODUCT. THEY ARE LEMONS.
Kenmore you failed. Claudia Bennett, Boston
claudiabennett80@aol.com
I should have kept the older unsophisticated model ...my basement smells...I did not know I am supposed to be a technician to wash my clothes!!!!!!!!!!!!
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Hello sir,i have a kenmore series 90 washer & dryer.this specific machine has top dispensing detergent/bleach&softner.when it becomes time for the softner to be dispensed on the re-fill the machine...
PLease check the hose that goes from the INLET VALVE to the dispensing system cup on your washer. This hose probably has a hole or the plastic dispensor is cracked and therefore leaking.
The inlet valve is working and when the time comes the water goes to the dispensing cup, so the system is working it is just the hose, dispensing cup or both.
Nov 19, 2009 | Kenmore Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
That is a bad water valve. Try my washer PICTORIAL for directions on replacing that water valve. NOTE: this is a pictorial of how to replace your drive coupling but you need to bust this ****** loose to get to that valve.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
Ge top load washer keeps filling with water
most common leak point for washers is the level sensor connector on the lower part of the tank, a small plastic hose.
Not a solution, something to check
Jul 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore Elite
could be spash over be sure washer is as level as possible
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
201 people viewed this question
Sal De
fordexpert
Robert Rankin
