Question about Mitsubishi VS-60601 60" Rear Projection Television
Mitsubishi VS-60601 60 in.
We were watching a program and it was fine, the next thing we know it went black and now nothing. What's the problem and is it worth fixing?
I just encountered the same problem. What was your solution?
Posted on Jan 22, 2010
I have a Mitsubishi vs-50604 and I was watching the TV and there was a popping noise, the TV went out. There was the familiar smell of burned electronics and now the green light flashes in sync with a...
Hello:
This may be due to failure of the power supply or related circuits,the burning may of been a capacitor or capacitors that may of exploded, changing these will return the set to normal.
Oct 05, 2011 | Mitsubishi VS-50604 50" Rear Projection...
I was given a Mitsubishi vs-50111 I was told all it needed was to be adjusted due to the color being out of alignment however i let the tv sit for 3 days and when i plug it in i get nothing when i try to...
You need to be concerned about the convergence board. This is the board with all the RCA jacks and RF connections. Pull this board out. You will see two very large cooling fins [heat sinks] with two large ICs [black with about 15 pins each. Marked with #392 ---] I don't know the exact# right now. Replace these Ics. And check the small resistors that stand tall next to theses Ics, replace if necessary! Let me know what you find.Thanks for asking me!
Aug 22, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-60703 60 in. Rear Projection Television: I was wondering if anyone could help me out with a question I have about my Mitsubishi big screen TV, model # VS-60703? My TV powers on and off, but...
try unhooking the switches and see if it will work with the remote only.
http://www.fixya.com/support/r5000958-fixing_mitsubishi_rear_projection_tv
Let me know if I can be of further assistance.
Jun 09, 2010 | Mitsubishi Televison & Video
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Big Screen TV VS 5043
depending on the model it could be serveral things. it could be convergence ic's gone bad or a problem with the power supply, something is shuting it down . contact mitsubishi for your nearest sevicer
Oct 19, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Messed up Image
bad connection on convergence amps or need to replace them
Oct 11, 2007 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50VA1
Go to http://www.remotes.com enter in the TV model number, and order it, as there is nothing that can be done in a case like this. You could try to borrow a remote from a local store to switch the set back to the tuner section or borrow an original remote from someone.
Sep 21, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
