Question about Lexmark Color JetPrinter Z23 InkJet
Lexmark z23 will not print
I have a Lexmark Z23 printer that moves and
acts like it's printing but yet nothing actually prints with ink on the
paper. It is a new cartridge so it isn't an empty cartridge,
I really need help with this. Nothing prints
out on paper but yet it acts like it's printing. I've tried about everything
I can think of, now maybe some one else will have ideas that will actually
make it work. Thank you.
    Sergeant:
  • 276 Answers
Go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Posted on Nov 20, 2008
  • 30 Answers
SOURCE: Lexmark Color JetPrinter Z23
In this model, if the colour does not work then your colour cartridge is either dried up or empty. Try running a few head cleans through your maintenance section and see if it rectifies the problem. If not a new cartridge will fix the problem.
Posted on Feb 04, 2008
fixyaixya
  • 34 Answers
SOURCE: Lexmark z23
you need the Lexmark z23 driver installed on your computer first. Here is the lexmark website. just download the driver and install it. Once that is done you should be able to chose it when printing.
the following link is for your printer.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:285:0:0
Posted on Oct 23, 2008
  • 57 Answers
SOURCE: Lexmark Z23 problem
Use a different usb port in your computer. but before you unplug it and replug it make sure your printer is off. Then plug it into a different port then turn it back on.
Posted on Jan 04, 2009
  • 7 Answers
SOURCE: Need drivers for lexmark z23 to install on vista
They don't make a Vista driver as it is an old printer but the XP driver might work, just ignore any messages saying it might be incompatible and install the diver, if it doesn't work, uninstall the driver and buy a new printer.
Here is a Vista driver link, try it no guarantees though.
http://www.bestdrv.com/lexmark_z23_33_driver_67699.htm
Posted on Jun 19, 2009
  • 35 Answers
SOURCE: Lexmark Z23 driver for Vista OS
Try to google it , or go to your manufacturer's website and ask for a driver there. You can select there whether what OS you are using.
Posted on Jun 22, 2009
My lexmark z23 printer keeps leaving blots of ink or marks all over the pages that it prints
You may need to clean the nozzles on your cartridges. Please follow the instructions in this article in the Lexmark website on How to Unblock (Clean) the Cartridge Nozzles in the Lexmark Z13/Z23/Z33 Color Jetprinter.If problem continues, try to insert a different known working cartridge to determine if your other cartridge is faulty. Thanks.
Feb 23, 2011 | Lexmark Color JetPrinter Z23 InkJet
I have installed new drivers and new print cartriges into my Lexmark z23. The test page will print, but when i try to print any other documents, they come out blank??
Good day!Is your new driver compatible with your Lexmark printer?and is your cartridge had no defect?..try to calibrate the cartridge..look to the manual of the printer..
Regards,
mastergani
Mar 21, 2010 | Lexmark Color JetPrinter Z23 InkJet
Paper won't feed. need button press for each sheet; z23 lexmark printer.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 21, 2010 | Lexmark Color JetPrinter Z23 InkJet
Printer sounds as if it is printing, paper runs through,
Have you tried to clean the nozzles?
Did you print a test page after installing the new cartriddge?
Go there http://www.lexmark.com/publications/pdfs/z33/enuserlx.pdf
Sep 26, 2009 | Lexmark Color JetPrinter Z23 InkJet
Printer acts like it is printing and sounds like it is printing but the paper is blank The test page does print
There are 2 probable cause, your ink is not fix properly or the machine is not closed in proper. The ink could not touch the paper beacause there is a small gap between the two that is why can not perform printing. Try to push a little bit harder to close the machine. Same problem happened to my printer once.
Feb 24, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23 won't print and when i do the wizard hardward installation it said that it cannot find software location. Can you please help me?
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23
DONT GET THIS Z23 PRINTER ,its a mechanical problem, the problem its the rollers , where you see some wheels inertchanging with each other , check for some broken teeth on these pulleys , printer suffers this problem ,
Apr 07, 2008 | Lexmark Color JetPrinter Z23 InkJet
Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Mar 06, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark 710 printer
the ink cartridges may have dried up. try getting one color cartridge to test (color because it can also print black).
Sep 03, 2007 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23 cartridge banging
Unfortunately, this is a known problem with Lexmark printers. First, try turning the printer upside down and shaking it - it's been known to work. If it didn't help, try cleaning the parts with alcohol solution. Wipe everything inside including the top strip, the metal bar and then pull the ink cartriges out and wipe the copper and the actual cartrige too. And to finish it, hit the side of the printer a couple of times.
Apr 04, 2006 | Lexmark Color JetPrinter Z23 InkJet
Lexmark Color JetPrinter Z23 InkJet Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
