Question about Whirlpool Dishwashers
Dishwasher leaking at the bottom of the door during operation.
  • 1 more comment
  • klamermari Sep 12, 2008
    need a solution for whirlpool built in dishwasher that leaks under the door during operation.What could be the problem. Hose coming in looks okay?
  • klamermari Sep 13, 2008
    abhisek33: Thanks for the info, but none of the things you suggested is the problem. I checked the bottom with it open during the wash cycle to see where it was leaking from..hose is good. Connections not leaking . No water on the floor below the dishwasher..It is only at the bottom of the door.in the front of the dishwasher...water level is correct in the tub. So it is possible the seal around the door is bad...it is around 15 years old..Guess it is time to call in a service tech? Thanks again for responding.
  • usmkenrobert Nov 25, 2008
    My Kenmore dishwasher is leaking from a hose in the door. Nothing major just an annoying drip. What is this hose? I can't find a schematic anywhere to show me what it is for!!
    Genius:
  • 1,239 Answers
Hi If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
thanks....................
Posted on Sep 12, 2008
Hobart sr24c is leaking water out the bottom of the door during operation.
You have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainage
Apr 21, 2016 | Hobart Dishwashers
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
My Dishlex Global 450 leaks, I have narrowed it down to the door seal and have replaced this. It appears to overfill during it's operation BUT not evry time? Sometimes it soaks the floor other times no...
Mine did the same thing. I cleaned the door seals, mostly the bottom one which collected a lot of grime & didn't provide a solid seal.
Hope this helps.
Jan 15, 2011 | Dishwashers
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
My dishwasher leaks at the bottom of door during operation and leaks heavily
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 20, 2010 | Dishwashers
Water flooding out of bottom of door during wash cycle. Door seal is good and nothing else is leaking. Thanks,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Leaking Dishwasher
heatman101
Sep 07, 2010 | Frigidaire FDBB1940D Dishwasher
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Door of dishwasher is leaking at bottom left corner.
HI. the door seal has been compromised. it could be simply farad or slightly propped open by some sort of debris as well. check the door seal for faults. replace if faults are found.
Also, make sure the door isn't mis-aligned. this will happen over time during heavy usage. re align the door if necessary.
Sep 22, 2009 | Frigidaire Dishwashers
Door leaks
This dishwasher has a vent at the bottom left of the door that blows out hot moist air during the drying cycle. Are you sure that you are not getting condensation build up from this vented air that is dripping on your floor?
Dec 29, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
544 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
