Question about Bissell 1672 BIGgreen Wet/Dry Vacuum
Bissell big green clean machine trigger problems
I have a very old Bissell Big Green clean machine, green canister with a long handle deal. My "grip/trigger unit" the little lever you pull up with you finger is broken or something it doesn't let the liquid flow anymore. Its like loose and not usable. Is there a picture or something of how it looks inside and how it is supposed to hook up inside with the screws out of the handle. The manual doesn't show how it looks inside the handle it self, Maybe something is broke off or something. thx k Mclaren email kittaroo@clearwire.net
SOURCE: Bissell Healthy Home
I had the same issue after using it daily for over a year. I checked everything and found no clog. I brought it to a vacuum cleaner repair center and they found a clog in the motor. It cost me $25 and was well worth it. I love this vacuum
Posted on Mar 01, 2008
SOURCE: Bissell ProHeat Carpet Steam Cleaner stopped spraying.
Problem could be a stopped up heater unit which is located in the handle. The two clear hoses going up the inside of the left wheel go to the heater. There is also an in-line water switch located directly above the heater. The trigger for water release is in the top part of the handle. back to the heater... mine was corroded inside. Removed 5 screws holding heater cover. clean water trough and reassemble. If you need new washers go to Ace hardware. The smallest size metric rubber washers seem to work fine. take old rubber washers(red?) with you for comparison.
Posted on Mar 03, 2008
SOURCE: Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Posted on Sep 20, 2008
  • 55 Answers
SOURCE: I have a Bissell Powersteamer & it won't throw out the water.
You can test the trigger to see if that is the problem. Take the two handle bolts out, gently pull back on the tool rack and slide the handle up off the unit. If you look down inside of the unit where the handle was you can see the valve that the handle used to actuate. You can turn on the unit and manually activate the valve with a long screwdriver. If it starts working then you know it was the upper handle.
Does it spray out the tools? If it does then you have a clogged heater. It is located in the lower handle and can be taken apart and cleaned out.
Good Luck
Posted on Nov 25, 2008
SOURCE: Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Posted on Mar 11, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Get Bissell little green pro heat to spray?
    These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
    Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
    Bissell big green clean machine extention hose not spraying
    Hey, sorry you're having difficulty with the spray on the hose.
    Here's a quick link to troubleshooting steps to assist you:
    http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
    Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
    How to take apart bissell little green carpet cleaner to clean it
    You may want to have a qualified technician at one of our Authorized Service Centers clean your machine.
    http://www.bissell.com/service-centers/?cid=ccsocial
    Jan 19, 2013 | Bissell 1720-5 Little Green Turbobrush...
    Trying to find replacement part for a Bissell Power Steamer Deluxe Model 1631-1, Part Grip and Trigger Assembly Part No. 016-4181
    http://www.bettervac.com/bissell-016-4181-handle-assembly-for-big-green-machine.asp
    Hopefully this helps.
    Mar 31, 2011 | Bissell Vacuums
    Bissell 1672 BIGgreen Wet/Dry Vacuum Logo
    341 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
