I Have an Ampeg AX-70 it goes back and forth at will from channel A to channel B.
2 Suggested Answers
  • 4234 Answers
SOURCE: when replacing the 12ax7a tube in my ampeg ax-70,
The short answer is 12ax7a and yes. If the problem is a defective tube, then replace it with another of the same type. The tube will be tight int he socket adn will require a tipping slightly in a circular motion to work it out of the socket. Pay attention to the key (space) when inserting the replacement.
Dan
P.S. Depending upon the sound you want, you can replace the 12ax7a with a 12au7 to get a softer sound. Both tubes are pin adn circuit compatible.
Posted on Jun 07, 2010
Can l get a drity guitar sound with my ampeg vt-60 if so how?
The VT 60 was made in the USA and was a very good sounding amp introduced by SLM (St. Louis Music) in 1989.
There are three channels: clean, crunch and overdrive.
You should be able to obtain a decent dirty using crunch channel but if I remember well you MUST have the dedicated pedal to switch channels and reverb.
Oct 15, 2015 | Ampeg Music
Tip
Clear BIOS Password, All tricks !
1.png?v=20100715113854 At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
on Jul 16, 2010 | Computers & Internet
I have an ampeg tri ax vt 60. Probably from 80s. I need ANY information on wiring please. Its been taken apart HELP
This does not sound like a motorcycle under which class it is posted. Maybe try guitars or amplifiers if that is what it in fact is.
Nov 18, 2014 | Audio Players & Recorders
How to check date of production by serial number
Ampeg' website: Welcome To Ampeg
There are also numerous forums on this topic.
Good Luck!
Jul 19, 2014 | Ampeg Music
My ampeg BA115HP is dead. I suppose it is the fuse. Where is the fuse located?
it's the black thing sticking out of the circuit panel on the back of the amp
May 22, 2011 | Ampeg BA115HP 1x15' Bass Combo Amplifier
All the inputs on my ampeg bass amp are not working even the RCA input is not working. the amp still turns on
If none of the inputs work, then you may have lost part of the power supply. DO NOT go into this amp under any circumstances !!!!...there is enough voltage in here to kill you crispy !! I would strongly recommend that you take it to a respected repair shop that specializes in guitar amps. Possibly visit the ampeg website for an authorized repair center. It might cost a few bucks, but the Ampeg is highly sought after by musicians everywhere !!!....thanks... Rob
Sep 01, 2010 | Ampeg Classic Series Svtvr 300watt Tube...
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
I've a problem with my AX-496..It's like this...when I make it on,it plays the music,but I can't make it louder cause when I make it,it goes for it self off...to stand by....so please any one help me... I...
Not a burned fuse - THAT would be a solid failure.
It's trying to tell you there is a short, tempertature or current overload. Disconnect the speakers and see what that does. While you're at it look for frayed wires contacting things they shouldn't.
Another possibility is the speaker impedance switch on the back being in the wrong position or between positions.
Feb 12, 2010 | Yamaha AX-496 2-Channel Amplifier
No chann. 70 on Uniden 525 marine radio
You can't "select" channel 70, nor can you talk on channel 70. Channel 70 is reserved for the exchange of digital data between radios.
And it is not possible to address an "emergency" (do you mean distress? or urgency?) message to an individual recipient.
Your radio is not allowing you to do any of these things because it has been (correctly) programmed to discourage you from doing things that would be illegal.
If you set up a routine call with your friend (or anyone else), you should find that once the two radios have completed their (almost instantaneous) exchange on Channel 70, they will both switch to whichever working channel you had selected, and he will get a beeping sound to tell him that there is an incoming call.
Sounds to me like both radios are doing exactly what they are supposed to.
May 17, 2009 | Uniden Boating
277 people viewed this question
 Grubhead
Grubhead
