Question about Aiwa HT-DV1 System
Still not working
I've Cleaned the lens,but the problem still exists.
    President:
  • 3,130 Answers
Is it possible for you to see the lens while the disc in on the platform or turntable while its tring to see the disc?? if you can manage this see if the lens moves up and down . If it does then the units trying to focus but cannot. as it needs to focus on the surface of the disc to reconize the disc or to start it spinning. If its trying to but dosent it could be the spindle motor or the control curcuit, the laser its self but not likely as alot of repair peeps blame the pickup assy but motre then 3/4 that are returned for warrantee replacements have been found not to be defective, the turntable could have slipped down, or it needs a foucus offset or focus gain alighnment. In any case your gonna need to probably take this to a good audio repairperson to see what the treue problem is. Good Luck
Posted on May 11, 2006
CD player skipping. Cleaned the lens but problem still exist
Try cleaning the disks as fingerprints and scratches can lead to read errors which are heard as skips.
Some cleaning solutions or reconditioners contain a special polymer that will fill in light scratches.
Apr 13, 2015 | Audio Players & Recorders
I've had my T3i for about 18 months. Suddenly, I am getting an Error 01 when using my CANON EFS 55-250 lens which has always worked fine before. Any ideas? Cleaning the contacts has not helped.
Without pulling the error codes I can't give you a firm cause, but the most common reason you get erratic error messages is a failure of the aperture unit in the lens (or sometimes the IS unit). They are connected to the back of the lens circuit board by flexible circuits, and as you zoom them back and forth you get cracks in the flexes, like you used to get with the old point and shoot AF film cameras
Mar 17, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 | Cameras
I dropped this camera accidently in the sand at the beach.I've cleaned it out the best I can but the Lens evidently still has sand particles in it. when I turn on the power it reads "Lens...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 10, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Hello. My DVD player will not play past the first few seconds of DVD. I've tried with 3 different disk and the same thing happens. I've cleaned all disk and still haven't been successful....
What I can think of the Lens inside your player may have dust etc on it.
If you have a CD/DVD Lens clearer disk try that, Then see if you can get it working better.
Jul 28, 2011 | Televison & Video
My Nx-385 will not play. When I put in a disc the player attempts to read then the display screen shows the word disc. What should I do?
It sounds like there is a problem with the Laser not picking up the CD.
If you've tried a Lens Cleaning Disc or Cleaned the Lens directly with a QTip and Lens Cleaning Fluid then the Laser has failed and wound not be cost effective to replace.
May 07, 2011 | Naxa Electronics NX-385 Personal CD Player
When I put a DVD in it says ''loading,' but never plays It continues to display, ''loading''
See if you can use other DVDs and see if the problem still exists. If it does, use a lens cleaner and have the lens cleaned. See if it helps.
Dec 11, 2009 | Sony DVP-NS300 DVD Player
Cd and dvd drive do not read anytihing
Your CD rom lens needs to be cleaned by a lens cleaner...
Dec 24, 2008 | Acer Computers & Internet
Cant load disc
I was having the same problem with my pvd-702...I genlty cleaned the lens with a dap of alcohol on a q-tip. I blew the lens so it was dry and the dvd player started working. No need to try to call the 1-800 number, it is disconnected and the warranties are not valid, because the address does not exist. try the q-tip, it worked for me.
Mar 20, 2008 | Durabrand PDV-705 Portable DVD Player
Aiwa HT-DV1 System Logo
41 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
