Question about Epson Stylus 777 InkJet Printer
Epson stylus 777 printer
The Low ink light is on. I replaced both ink cartridges with new ones. The power light and the ink light are both still on. I dissassembled the printer cleaned the nozzles with mineral spirits. The carriage will move back and forth but still no printing. Ps. I can t get the cleaning cycle to work either. Epson has a help phone # you give them your CC# and maybe they will tell you its time for a new printer! Thanks, Gerry RRT.
  • gerard lawrence May 12, 2006
    Thank-you very much again TECHMAN. I founthe service manual on esi.com. Tonight I will try to adjust the timing! I will keep you posted much obliged. Gerry
  • Anonymous Mar 24, 2014
    need to find icon to help me clean nozzles on Epson stylus printer 820
    President:
  • 3,130 Answers
Isent this the same printer that you asked about with a problem with the carrage not working correctly after disassembly to rerplace a roller?? If it is then you ptobably have a sensor misalighned or unit still is not "timed" correctly.
Posted on May 12, 2006
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
How to Change ink cartridge on Epson Stylus SX215
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Sep 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus 777 InkJet Printer Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
