Question about LG LHD65EBL Dehumidifier
LG dehumidifier We have a LG dehumidifier. It runs for few minutes and the bucket full indicator turns on, and the dehumidified suts off, if I adjust the bucket little bit, then it turns on. but after 2-3 minutes, samething repeats?
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Posted on Oct 05, 2008
Bucket is empty but it wont run, bucket is full light just flashes.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Mar 01, 2011 | LG LHD45EL Dehumidifier
My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Feb 25, 2011 | LG Dehumidifiers
Nno much water generated
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
Take care.
Aug 01, 2010 | LG LHD45EL Dehumidifier
Leak, non sensing
I have found this issue to be pretty common on alot of LG dehumidifiers. Try and reseat the bucket so the left and right sides where the bucket meets the dehumidifier are both flush with the dehumidifier. The issue usually is you will notice that the left side sticks out a little farther than the right side. If this is the case that means the bucket s not fully engaged with the sensor and it will keep running even when the bucket is full. If you reseat the bucket and both sides are not even try reseating it again until both sides are flush. Once they are flush let t run and keep an eye on it the first time running it like this. You should notice the full bucket light when the bucket is full now. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 09, 2008 | LG DH404E Dehumidifier
LG LHD65EBL Dehumidifier Logo
776 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
